Mitsubishi WS-55819 55" Rear Projection Television Logo
Anonymous Posted on Oct 01, 2011
TV displays green blinking light but won't power up
Anonymous
Level 2:
New Friend:
  • Expert 49 Answers
  • Posted on Oct 26, 2011
Anonymous
Expert
Level 2:
New Friend:
Answers
49
Questions
Helped
10292
Points
107
This is sometimes called the "blinking green light of death" and usually means the DM unit in the set needs repair.
The only other simple thing may be the reset switch on the front of the set has gone bad; The only way to see is to get at and unplug the front keyboard on the set.
I can tell you how to do that if you want to know.
Takes about 5 minutes and if set still does not come on then the DM unit is bad.
sj
  • Anonymous Feb 26, 2012
    I HAVE FIVE SO CAN YOU PLEASE TELL ME
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jul 23, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
371
Points
Don't freak out. My DM went bad and I replaced a resistor on it for 15 cents. However, if you take it to a TV Shop, they want 800 bucks to replace it.
PS3 3D TV Display Doesn't turn on 2 red blinking lights
HI, in this video you will find how to fix your Sony 3D Display
https://www.youtube.com/watch?v=OdPGSZnTIPw
TV won't turn on
Before going OFF, the standby LED might blink. These blinks are fault indication. The number of blink should be counted. Count the number of blinks at one time, before the TV goes OFF. [eg: 4 blinks Power SOS P Board; 6 blinks Driver SOS 1 SU / SD / SC Boards
(SC energy recovery circuit)] and so on. you can get more details from this site named 'Electro-help'. You can reach it by searching the keyword "electronicshelponline" by internet.
Green light blinks three times but T.V won't power on
Power supply probably fried. You will have to take the TV apart to test.
Popping noise and now won't power up. Red and green indicator lights blink on front of tv.
start by checking the power supply in the set and if not able to do that consider taking it to a shop for an estimate.
1helpful
2answers
Green timer light won't stop flashing on mitsubishi ws 73711.
the green light blinking is normal if set has been unplugged--when set is plugged back it should blink for about 70 seconds and then go out--then you can try to turn it on---it is the DM unit inside the set booting up.
If the light just blinks and never stops you have likely bad caps in the DM unit---there are kits available for that.
The other possible reason is that so called reset switch may be bad--fairly easy way to find that out and it is more common than you would think, let me know if you have questions.
SD TECH
My mitsubishi tv W55613 won't turn on. green light keeps blinking even after resetting
Hit the front of the tv near the blinking light... give it a good rap or two. See if this helps. Helped mine. I had the same problem and the tech who came out to the house told me that it would work and it did! I could hardly believe it but it worked.
2answers
Panasonic tv powerlight blinking,tv turning off and then back on, now it won't turn on at all, blinking green light goes red and it shuts off completely
My TV surname off after 5-15 minutes of use. The red light in the front blinks once every 3 seconds continuously. If I hold the power button down on the tv, it will turn on and do the same thing.
1helpful
65" mitsubishi rear projection tv won't turn
IF model number posted is correct and green power light comes on for a few seconds and then goes off:
On front of set press and hold both the Menu and Input (device) buttons at the same time for at least five seconds and release both buttons.
Power light will then blink a two digit error code like 2 blinks, 2 blinks, a pause and repeat it several times.
Let me know what error code is found and I will tell you what it means.
SD TECH
Describe your WD-62725 62 in. Rear Projection HDTV-Ready Television Problem Green light is blinking the TV won't turn on. We've unplugged it and tried to push the reset button and the green light...
If the led light flashes green continuously, the fault came from the DM power supply. The faulty parts there are the electrolytic capacitors. Let me know if your handy with electronics and I will assist you to fix it yourself.
Jdvillanueva
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
