SOURCE: Ear Jack
Theres a good posibility that the solder connections are the only thinbg wrong with the connections BUT theres a possibility that the Printed curcuit board its self is a flex board and that the flex connections are torn. If thats the case you probably wont be able to fix the unit. If you can open the unit then you can look at the connections and see if its just plain old solder connections?? Good Luck
SOURCE: iPod- right earphone doesn't work
Yes, the headphone jack will need to be resoldered back in place. You can get it fixed at a computer repair shop or electronics shop. It shouldn't cost that much to get it repaired. Good luck to you:)
SOURCE: fix my archos 404
Can it be fixed, yes. However, the replacement panel will probably cost $150 or more. Given that the original cost of the player is $179, I don't think it is worth it. The labor cost will make the repair exceed $179.
Dan
SOURCE: Archos 605 WiFi "Cannot play video! Please Check"...
Happens to me at least once a week! Use the reset button - works every time.
