Troy-Bilt® Briggs and Stratton Chipper  Logo
Anonymous Posted on Sep 30, 2011
I have a Troy Built pressure washer model 020245-1 (Briggs and Stratton) how do you adjust the unloader stem?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Apr 11, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1119
Points
I need a gas tank for a 020245 Troy- bilt pressure washer 2200.
2 Related Answers
steve_lima
steve
  • 181 Answers
  • Posted on Jun 26, 2009
SOURCE: Describe your Troy Troy-Bilt® Briggs and
there should be a set screw in the impeller holding it on the shaft.take the set screw out.then the impeller should come off.if it doesn't come off easily you need to heat the hub that the set screw was in.this expands the metal so that the impeller will come off..........there is no easy way to do this job........hope this helps,let me know..................
rwvanlue
Roland W VanLue
  • 486 Answers
  • Posted on Nov 08, 2009
SOURCE: Misplaced operation manual for Troy-Bilt Briggs
Straight 30w NOT 10w-30
prefer air-cooled engine oil from mower dealers or some auto supply stores have air cooled engine oil.
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Troy Bilt 3000 psi, 2.7 gpm Power Washer with Briggs & Stratton 875 series motor. It stalls on trigger release?
Question edited for clarity, full make model (what it is)'.
It is a known issue. Check or replace the Unloader valve. Strip and clean the carburetor. Adjust the running speed.
https://www.google.com/search?q=troy+bilt+3000+psi+stalls+when+trigger+is+released
Aug 20, 2022 • Troy Garden
I need a carburetor for my Troy built pressure washer with a 190 cc Briggs and Stratton engine
there will be a name and model on the side of the carby ( if you still have it) just match it with carbys on e-bay
Apr 03, 2017 • Troy Garden
Where is the choke on Troy built pressure sprayer 7.75hp?
That model has an automatic choke.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_a3dac712db4ca1a6
2helpful
How do I change oil in my Troy Bilt Model 020245 pressure washer
if its a vertical engine it;s underneath the base of motor look for a plug with a square slot in it i usually use a 3/8 " extension
Change oil in Troy Bilt 020245 pressure washer pump
underneath base of motor look for a plug wuth a square slot,i normally use a 3/8" extension with ratchet.
Change oil in Troy Bilt 020245 pump
if it,s a vertical motor it's at the base of motor look for a plug with a square slot.
My Generac pressure washer will work great for as long as I hold the trigger. If I release the trigger to move something or change positions and then pull the trigger again the pressure doesn't come...
Sounds like the unloader valve built-in to your system is sticky. Try lowering the pressure of the regulator to lowest setting then re-adjusting. This will place a different pressure /load on the valve. Also when you store your unit, displace the water in the pump with oil so that lubricant will prevent the unloader from sticking. If you continue to have problem, replace the unloader. Good luck
6helpful
Unloader Valve - Karcher Pressure Washer
where is the unloader valve locaed on a Briggs Stratton pressure washer?
2helpful
Power washer will not draft
craftsman 2000 psi, model 020211, starts up and runs good just lost pressure?
Top Troy Heavy Machinery Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
john h
Thomas Perkins
Thomas Perkins
Are you a Troy Heavy Machinery Expert? Answer questions, earn points and help others
