SOURCE: I have a cuisinart with brew and grind coffee
Stuck? how stuck can it be when it is supposed to be removable? Try turn ing it,
SOURCE: Krups grind & brew. It grinds but water
Check to see if your heating plate gets hot when it is on, if it doesn't your water heater/heating pklate has failed.
SOURCE: KRUPS KM7000
Check to see if your heating plate warms up, if it doesn't then your water heater/heating plate has failed.
SOURCE: Krups KM7000 grinds but won't brew, warming plate
Mine had the same problem ... all the lights are on, but no heating on the plate, and no dripping of water.
After a weekend on the workbench, I've mastered this machine. The KM7000 has 2 x MicroTemp G4 thermal cutoff (TCO) fuses which interrupt the Live line, for overheat protection. Mine didn't overheat per se, but the TCO blew anyway. Not reset-able ... need to be replaced with a soldering iron. I'll be happy to advise you to fix this, or fix it for you. Write me at [email protected].
SOURCE: Krups Grind & Brew KM7000
The grinder is activated by a microswitch inside the grinder housing. Under normal circumstances, the microswitch gets closed by swinging the filter lid 'away' from the filter (i.e. into the grind position).
Unfortunately, sometimes the microswitch works itself loose, and no longer closes when you swing the filter lid open, so the grinder doesn't come on, since it thinks the filter lid is still in the way.
This seems to be a common problem with this rig. I'll be happy to advise you to fix this, or fix it for you. Write me at [email protected]
