SOURCE: I am having htc wildfire.
U CAN DOWNLOAD THE SOFTWARE FROM THE BELOW HTC SITE
http://www.htc.com/www/SupportDownload.aspx?p_id=316&cat=3&dl_id=1058
SOURCE: I am having htc wildfire. so i need pc suite for
hi,
Visit to the given link and download and install the "HTC Sync 3.0"...
http://www.htc.com/www/supportdownloadlist.aspx?p_id=316&act=sd&cat=all ...
hope this has helped you..
Please rate the answer.
Thanks...
SOURCE: hi there i would like to use my memory card as my
Your memory card cannot be set as the phones default memory, the only thing you are to do is to keep receiving the files on the phone and moving them to the memory card. HTC wildfire does not have the feature or function to be able to make your memory card your default memory storage. I hope you will be able to manage the fact that it cannot be set as default memory storage.
Hope this information helped.
Take care and good luck!
SOURCE: hi there my problem with htc
When you plug your phone in to the computer, a couple new icons should appear in your notification bar. Bring the notification bar down and click on the one to mount your phone as a drive. You may also need to turn on USB debugging.
SOURCE: the HTC Wildfire A3333 phone,
You can download and print the instruction manuals in PDF format by clicking these links:
User Manual
Quick Start Guide
Adobe PDF Reader is required to view the manuals. Download Adobe Reader
Hope this helps. Kindly let me know if you have any difficulty in downloading the manual.
Thanks for using FixYa.
