SOURCE: cooktop light stays on when cool
Please be more specific. A. What is the "plate cut-out"? B. How does one access it?
SOURCE: Kenmore 44083 Cooktop
should be an unlock button.....press and hold the button until it unlocks
SOURCE: glass top
The cooktop will need to be removed from the counter. Turn it upside down and remove the screws. The biggest problem will be removing the cooktop from the counter. Sometimes it is not worth fixing as the part could cost around $400. NEVER use a cracked top as it could suddenly explode. This is tempered glass and very unstable if cracked or chipped.
SOURCE: Frigidaire electric glass cooktop wiring problem
HEllo
I have the following manuals in PDF format,
I will gladly email them to you.
Model:
GLEC30S8ESB
Owner Guide(English):
318200612en
Wiring Diagram:
318046807
Installation Instructions:
318201426
Parts Manual:
5995479655
Eddie Rentas
Tupper Lake NY
SOURCE: Corning cooktop burner outage
The cooktop has to be examined for failure of the element or the switch. Some of the switches & some of the elements are still around. Have the elements checked for continunity. You will have to take it out of the counter and take the unit apart to do this.
