Broderbund PrintMaster Gold 16 for PC Logo
Anonymous Posted on Sep 29, 2011
I go to save a project and it closes down on an error.
1helpful
2answers
Project 2010 - Unable to open file error
This is vital point which can be consider as workaround:
v Go to the document library in which project files resides
v Hover your mouse to any project file and select 'edit in Microsoft Office Project'
v It will give you a pop up by selecting the 'SharePoint drafts' option
v Click ok / you can do a check out also by selecting the 'SharePoint draft' option
v Now the document is in check out condition so go to the SharePoint drafts location on your machine (Location: \My Documents\SharePoint drafts)
v Open the document by means of draft location, do the changes and save it.
v Go back to the SharePoint site and check in the document.
v Changes will be successfully saved without any problems
Try to install this app Recovery Toolbox for Project
http://www.project.recoverytoolbox.com/
Here's one thread like yours. It could be useful for your, read http://www.filerepairforum.com/forum/microsoft/microsoft-aa/project/625-project-error-"an-import-error-occurred"
When i click to print, or save document. it gives me an error saying. --the application is low on memory. this may cuase problems printing or saving your project. Try closing some projects or using fewer...
Hit Ctrl, alt, delete at the same time and start task manager. That will show how much mermory and cpu are being used. At the top if u select applications you can see what is running. Right mouse click an app and chose close and it will free up memory and cpu. Select processses and again you can see the above and right click apps to close them
3helpful
Data saving error
I came to the point where I had done everything, restarted, closed the program in the task manager nothing would work. Every time I would hit any key even the X to close the program I would get the error. data saving error enitity exception. So finally I shut down the computer, disconnected the battery, waited about ten minutes started back up and so far it has worked without problems. Ever since My Deluxe Invoices made their last up grade I personally have had lots of issues with the update. Wish I could go back to one of the very first versions but with the ability to email statements. Thats the only upgrade I have found useful.
1helpful
2answers
Cannot open file - "Unexpected File Format"
Does the program allow for "auto back Up?" if so I would look in the folder of the original file and look for one closely named but probably with a different extension, if it exists rename it a different name than the original and with the proper extension. then try it. If not you have probably lost your work due to improper closing of the file when your computer crashed. You could try the manufactures web site and look for a corrupt file recovery tool of some sort. Sorry I could not help more.
Saving projects
I have not used Print Shop in years but i always was able to save to a file then save it to a disc using cd writing software. Just take notice of where your files are being saved. I think you can use the save as function and choose a spot to save it for easy retrivial then close the print shop and open up cd writing software and save the project to a disc.
5helpful
2answers
Cannot open file
Sir, I was working in a PM file. Computer shut down before closing the file. While opening the file Showing " Cannot open file. closing publication, some work may be lost. open the previously saved publication (8009:20551) "Continue" While clicking continue not opening the previously saved file.
2answers
SAVING FILES
can you plz tell while working ,in which software do you get this error
Top Broderbund Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Broderbund Computer and Internet Expert? Answer questions, earn points and help others
