SOURCE: rca F32649 32"
I had the same problem and eventually found the solution. the tact switches behind the front panel buttons will leak when they get old causing them to activate on their own. your channel up or down button is stuck on. take off the back cover and you will see a small clip in circuit board behind the front panel. take out the board and remove the channel up or down switch and your set should work fine again. the remote will still work fine for changing the channels.
SOURCE: Channels keep scrolling
Check for a channel button on the front of the set.. one of them is sticking. Try spraying some WD40 around the front buttons and work each one to make sure none are sticking in..
SOURCE: TV scrolls through the channels, over and over. Go
go to menu go to gemstar setup, set your zip code to 99999 and then exit. this solves 90%
