Sony Cyber-Shot DSC-P32 Digital Camera Logo
Anonymous Posted on Sep 29, 2011
My carr stereo abt-p3200bt works good but the cd don't work way?
1helpful
I have a 2000 alero & my engine has abt 215k miles
May have a bad head gasket
Is what an easy fix?
If you don't work on motor vehicles,
then where else would you go?
I have a recently purchased 2003 Renault Vel Satis fitted with a radio / multi CD player. The CD player works, the radio seems to be tuning into radio stations however, unless I turn the volume up to...
I'm sorry, but that's just an awful car to have purchased. Faults gallor I'm afraid. Even some of us experts would gain valuable expertise working on a car like that.
There is almost no online help for French cars as most people with experience like myself tend to stay well clear of them.
Your present issue is a failed stereo head unit.
Good luck with all the others you will no doubt have though.
Sorry for the bad news, and good luck!
Don't take it the wrong way. I am talking about the car being of poor build and quality, not the owner. It's anyone's mistake to own a French car once in a lifetime.
AVH-P3200BT MANUAL
http://www.pioneerelectronics.com/PUSA/Car/DVD-Receivers/AVH-P3200BT
Just click on the 'Manuals & Brochures'.
1helpful
2answers
I have a RDS stereo and it won't play my cd's. It says player error
RESET YOUR PLAYER AT DEFAULT SETTINGS. SWITCH IT OFF. SWITCH IT ON AND INSERT CD. GIVE THE PLAYER TIME TO READ. DON'T PRESS ANY BUTTONS TILL IT COMPLETE IT'S READING. IT WILL PLAY THE CD.
ALSO CHECK CD'S ARE BRANDED AND NOT COPY FROM COMPUTER. FEW COMPUTER WRITE CD NOT HAVE AUTO PLAY OPTION.
IF PROBLEM NOT SOLVE PLEASE INTIMATE.
The CD player in my factory stereo has a CD stuck inside of it. We know that the radio is programmed for this VIN # only. Can I unplug the stereo and fix the CD player and then plug it back in without...
Try disconnecting the battery for a few seconds and try to eject the cd, if this don't work you can take the cd player to the dealer ship and they can send it to be repaired
The unit worked fine for a long time. a few days ago i changed cds and when i put the cd in it sounds like it is spinning and then nothing and it ejects the cd..the radio still works on the unit. I just...
Some Panasonic stereo's don't like non shop bought, home burnt discs (they are recorded at a different level) so try new discs plus run a CD laser cleaner through your system.
2005 gmc sierra, replaced radio with known good radio with same part # and model #, all functions work but there is no sound from the radio or the key and door chimes. Is this a lock feature. Took vehicle...
i cannot understand how you radio would work. These radios are coded throught data link to computer. the only way to get the stereo to work is to run a calibration program through the vehicle. then it should accept your new cd player. if the stereo's are the same then may I suggest you to take the radios appart and switch the parts that don't work like CD drive assembly and faceplate.but use your factory installed stereo as the main core, this should fix your isses and work fine since the calibration is for the origional factory stereo.
Need code for blaupunkt 520 cd/radio BP8385X1713624
such unlock codes can only be obtained by following ways:
-go to the official dealer and request them an unlock cd.
-go to any car stereo shop and gt the stereo unlocked
-browse the internet for an unlock cd (making it is real tough and u cant do it until know many things both abt pc and stereo)
2answers
About spyware
you can use bit diffender its really good...
Top Sony Cameras Experts
ZJ Limited
ZJ Limited
Are you a Sony Camera Expert? Answer questions, earn points and help others
