Question about Onkyo TX-SR605 Receiver
WHAT speaker distace & delay .sitting and Db in my AVR AS MY ROOM SIZE
My room size is 16ft.1" X 17ft.3".00. Hight is 10ft. 6" .I have Onkiyo
898 A/V Receiver and thx certified LCR Speaker with 4 diopole surround &
back surround . L- C- R speaker & surround and two back surround are place as attech file herewith Ditance L-C-R 10ft .6 " & SURROUND LEFT & RIGHT ARE 8ft .6" and back left -right Back surround 6FT.6" ARE far from my iistaning -sitting . . I put SPL METTER incenter room and set at 82db in all speakers.i.e left +8 db , center +5 db, Right +8 db, right sur +2 db , back sur. left +4 db, right back sur.+4 ,& left sur +4 db Woffer JAMO D-7set near front Left at 9ft. 5" far my sitting on +3 db in ONKYO 898 AV RECEIVER. I got good sound .But WHAT & WHICH set delay AND
distance in A/V.So what do I do .Please guide to me properly for same and got
surround My room size is 17ft.10' x 16ft hight is 10ft.3". SIR, IN MY ONKIYO INTERRA TXS 898 A/VR NOT IN BUILT AUTO SET UP . NOE I PURCHASE ONLY AUTO SET UP (DON'T KNWO NAME OF INSTUMENT) WHICH CAN ATTECHE WITH MY A/VR AND CAN do ALL CHANELL -speaker 7.1 MAY I GOT DIAGRAM OF SETTING, DISTANCE, DELAYTIME, DESIGN SITTING FOR MY ROOM.?
  • Official Brand Answer
  • 333 Answers
Hello, if you have the speaker set up microphone I suggest that you use it to calibrate the speakers and it will set the distance and delay. Thank you, Onkyo USA
Posted on Mar 03, 2017
3 Suggested Answers
SOURCE:
techman
  • 3130 Answers
SOURCE: no surround sound
So your saying that you have no rear channel. Some recivers use a single stereo output ic for both sides on the rear speakers. you could have a defect with this IC . Anther thing Im sure you check3ed the obvious ie : the switch is on suround sound? If there is a front to rear fader is it in the middle? Good Luck
Posted on Jun 04, 2006
  • 17 Answers
SOURCE: Hi We are setting up our
Hi there. If you are running a 5.1 speaker system, make sure your surround speakers are on the surround terminal NOT ON THE SURROUND BACK. the surround back is only for the 7.1 speaker system.
Posted on Nov 28, 2008
Tip
How to install a 5.1 home theater system
1. Read the installation guidline/connection diagram given with the product.
2. u will get 5 speakers and a subwoofer. speakers are front left & right, rear left & right and center speaker.
3. install the front spearkers both side of the TV at ur ear level.
4. install the centre speaker at the centre above or below the TV at ur ear level.
5. install both the rear speaker at the back side wall corners (min 1.5 feet from ur sitting position) at a hight of 5 feet. face the speakers towards ur sitting position.
6. keep the sub woofer at the right side corner of the room.
7. note that the room should be a closed one with less air ventilession & use a carpet on the floor to get clear sound.
8. use co-excial or optical fibre cable to connect ur home theater system to ur TV, DVD player or audio device.
Now u can enjoy ur home theater.
on Aug 15, 2010 | Audio Players & Recorders
How much room space can this unit cools or can I use it for two rooms
Hello Ursella Thompson,
Absolutely no information came through with your question about... Room air-conditioners (make/model/size)...
Which is actually okay because those calculations...
immediately become quite complex MORE BECAUSE OF THE ROOMS (& your climate) than the air conditioner.
The size of the room... height... INSULATION.number of windows (fenestration) & doors (their relative insulation, composition & size... drapes, shutters. blinds, shades... storm doors (all kinds of considerations).
Sadly... if you are interested in a "cheap" air-conditioning solution
this is the area where the cheap immediately becomes EXPENSIVE...
I personally hate having strangers in my house... but this is and area where getting a "utility ENERGY assessment" might be a good idea...
Then when you are assured your house is as good as REASON/FUNDS will allow...
THEN get estimates from A/C Vendors...
or
Hire an actual ENGINEER to get an idea of what your air-conditioning requirements are..?
Check the internet: you will be presented with an array of sheets, formulas... magic tricks..
It is important to know it is a CRITICAL DESIGN consideration... and has its on field of ENGINEERS.
Hope this helps
http://www.bing.com/search?q=air+conditioning+calculator&src=IE-SearchBox&FORM=IENTSR&pc=EUPP_
Buy Goodman Heat Pump Geothermal Heat Pumps Goodman Air Conditioner
Jul 04, 2016 | Heating & Cooling
I have 4.50 speakers in the front of my toyota carolla and 5.25 speakers in the back can I convert them to a bigger size?
If there is room, you can change sizes. It's easier just to keep the same size and just get better speakers because certain door speakers require specific spacing and room for the magnet of the speaker to hit and retract effectively. But after upgrading to good speakers, you may want to run them thru an amp to get the full potential of the door speakers. If you hook it up thru your head unit it will be 50 watts max to each speaker usually.
Feb 22, 2015 | Toyota Cars & Trucks
10ft x 20ft how many cubic ft fit inside
That depends on the third dimension.
Imagine trying to put stuff into a room that's 10 feet by 20 feet. You can put more stuff into a room with a 12-foot ceiling than you can into the same-sized room with a 10-foot ceiling.
Apr 21, 2014 | Office Equipment & Supplies
What is the best way to set up my 5 inceling speaker system room size is 18x15 TV is centered on 15 ft wall 10ft ceiling ?
place your subwoofer approx 1m or 3 feet away from your media player, then one speaker below your TV, the other two in either corner in the front and the other two in either corner at the back of the room. try not to mount them too high, approx 3 feet off the ground or the same hight as your head when seated. this will give you the best sound quality. if the speaker is the front or back seem a little far you should be able to set the volume on each of them. if the back is further than the front then set the back speakers louder than the front ones or vis versa.
Nov 07, 2013 | Denon AVR-3806 Receiver
Sound cutting out after about one hour of use
You are PROBABLY driving it too hard and the thermal cutout is activating. This is only a 12 inch speaker and should comfortably fill a 20 foot square room. If *********** could not stay in such a room, you are playing it too loud. Try reducing the volume by 3 DB and see how long it stays on. The specification on MOST of these powered speakers and speakers and amps in general are victims of "specsmanship"... that is false advertising to make sales. This size speaker is NOT applicable to outside venues for the most part. You could also try putting a fan blowing on the heatsink to keep it cooler as that might help.
Sep 10, 2011 | Behringer B212D Powered Speaker (550...
Long delay between singing into mic and hearing voice in speakers
Usually delay is associated with "reverb" not echo. If you are in a large room, the room acoustics can add reverb without the benefit of signal processing.
Reverb NORMALLY passes the inout signal as is and then adds in a delayed version on top.
The delay should be less than the room size delay.
Try turning off all effects as a start. There is some "transport" time if it goes through a digital signal processing.
Apr 30, 2010 | Vocopro Da1000pro Professional Digital...
Denon AVR 1910 Volume Level
My Pioneer VSX-36TX (circa 2002) does the same thing. Modern AVR's count up from minus something to 0db and go just a few db higher into 'plus' territory. It seems arbitrary but that's how it is.
Ask yourself this: who ever really turned the volume knob up to maximum on any amp on purpose, and had speakers survive it? In other words, why have all that capacity on a potentiometer if you never use it?
Little known fact: With that in mind, Bose Corp actually designed a product that intentionally used the full physical travel of a volume control - the Bose Acoustic Wave Music System.
Feb 11, 2010 | Denon AVR588 Receiver
Im looking for the best avr reciever..for the money...i have a bigger room with sloped ceilings and the room echoes a little...its the liv room, kitchen,dinning room all rolled into one...about 20x20...
Only receiver that is better is one that has features that you want and need and do not currently have! Period. Unless you are an alien you cannot hear frequency response differences nor distortion on pure harmonic waves unless it exceeds 6%. My old stuff is still better than anything currently available - may not look as pretty but .........Other than that, the only really valid reason for another receiver is that you need more power because you like to blast and also add bass. (Every time you increase bass by 3 db you are making receiver put out twice the power at that frequency! 6 db is 4x, etc.) But spend your money - you are not going to get anything any better than your Denon - And if you want more power doubling the output in rms only increases the volume by 3 DB, the smallest difference that the human ear can detect. So if your receiver is rated 50 watts you get one with 300 or more to get any real increase in volume. Capiche?
Aug 26, 2017 | Onkyo Audio Players & Recorders
Onkyo TX-SR605 Receiver Logo
80 people viewed this question
Top Onkyo Audio Players & Recorders Experts
Ted28
Level 1 Expert
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
