Remove the key from the ignition and press the UNLOCK. its saying the alarm was triggered, eg if door was opened without first using the unlock on the remote. maybe when alarm was armed not all doors were fully closed. or you just reconnected the battery so the door was open without you ever pressing the unlock on the remote(which could be called DISARM the alarm)
SOURCE: is there a anti theft reset 2002 vw jetta
DEALERSHIP HAS TO FIX IT.ANY TIME YOU HAVE PROBLEMS WITH ANTI THEFT SECURITY SYSTEM THE DEALERSHIP HAS TO REPLACE AND REPROGRAM CAR.IT COULD BE KEYS WORN BAD OR IGNITION SWITCH AND PCM CANT RECOGNIZE KEY.THE CAR WONT CRANK.
SOURCE: 1999 VW JETTA anti-theft alarm keeps going off & car won't start
pop the truck and the alarm will disable
SOURCE: Why does the anti theft alarm go off on my 2002 VW
IT COULD BE A NUMBER OF REASONS,1-the interior monitoring sensor could be faulty,2-one of the door locks could be faulty,3-the alarm horn or the alarm control unit.suggest having a dealer check for any fault codes,if none they can also check which component was the last thing to set the alarm off using their diagnostic machine...good luck
SOURCE: car door will not open. vw 1.8 1999 passat
remove door panel and check actuator for power and that actuator rod is connected and the plastic clip did not break or pop off
SOURCE: vw transporter 05 central locking not working
water ingress in wiring loom below drivers seat, mainly loss of power to pin 23 middle multi plug blue and red wire middle multi plug.
remove drivers seat/frame trace wire back to corroded connection and repair. you may also have to remove passenger seat depending on where the break is. dealer quotes upto 2 hrs
