Microwave Ovens Logo
Anonymous Posted on Sep 29, 2011
My Jenn-air micro/convection oven runs, but there's no heat. I don't know how to use it as its all new to me.
Anonymous
Level 3:
  • Master 4,323 Answers
  • Posted on Sep 29, 2011
Anonymous
Master
Level 3:
Answers
4323
Questions
0
Helped
1232361
Points
12714
Hi
This means a loose/broken wire on the oven temp sensor or the oven temp. sensor itself is bad and should be replaced. To solve this issue test the oven temp. sensor, it should read between 1080-1120 ohms, if the rating is more then that and the door appears to be closing fine then it is the control board that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Jenn-air micro convection - cooling fan comes on when door is opened, then goes off, intermintent problem
I have seen where one of the door switches becomes intermittent causing the symptoms you are describing, tough to nail down considering there are more than one door switches.
Just wondering if I can use metal in my convection/microwave Jenn Air combo on the CONVECTION setting only.
On the convection setting it's just a regular fan oven, so you can safely use metal.
I want to bake a salmon loaf in a glass loaf pan in my Jen Air mincrowave/convection oven. The 4 pg. instruction manual does not give me sufficient info. In fact, there's onloy a half page relating...
I have a Panasonic Convection Micro. Yes, If you are using convection you can use metal pans. Microwave energy cannot pass through metal pans so that is why it is not good to cook in them. It could also cause arcing or reflect the microwave energy bak to the mag and over heat it. So, when possible use corning ware or Pyrex when using the microwave
Microwave is locked
If this is a problem of the control panel being locked, the instructions are posted on page 9 of the owner's manual. Press STOP/CLEAR, followed by pressing and holding the ENTER/START button for 3 seconds. The lock should clear.
If you no longer have an owner's manual, here is a link to a FREE copy:
http://www.managemylife.com/mmh/owner_manuals/15069/JENN-AIR-Countertop-Microwave-L0606616?brand_name_search=JMC9158
If I'm wrong in my assessment, or if you need further guidance, please post back and let me know. I hope this helps you.
Jennair JMC9158AA microwave not heating consistently - turntable moving, fanblowing - sometimes heats convection oven feature still working fine
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
My microwave will run, light will come on but it's not heating. The maid was here today and I saw her cleaning it. Could some button have been hit accidentally?
Basic Microwave Oven Troubleshooting Tips
heatman101
;0;0;0;0;0;0;0;0;0;0
JMV8208 BAW Model 30" Jenn-Air Convection/Micro combo
have a good look at front to see reset??.press it once it comes back on unplug from the wall and & open it up and go to the part and give it a good clean with wd40, check the push pad for ware & tare dirt gathers and builds up
Top Jenn-Air Microwave Ovens Experts
rajanshyam
Level 1 Expert
Are you a Jenn-Air Microwave Oven Expert? Answer questions, earn points and help others
