SOURCE: False Paper Jam
Hello, My name is Vikram Kumar Thumu, from India-Hyderabad. I have seen your message on the issue related to Paper Jam error messages even though there is no paper jam in printer . I would like to provide my suggestions on the issue. I hope that this should work for you and will resolve the issue. This issue could happen if there is an issue with any small paper jam in the Printer, or due to the communicational issue . To isolate the issue, I recommend you to perform below steps. Steps are: -------------- 1. Power OFF printer and then please Disconnect the Printer from Computer and then disconnect the Power cable of Printer from wall outlet. 2. Check thoroughly in Printer that there is no small piece of paper in the Printer. 3. Let the Printer be disconnected and idle for 5 minutes. Meanwhile please perform further steps on Computer. Note: The below steps are applicable if you are using WINDOWS 2000/XP/VIsta Operating system in your PC Steps are: -------------------- Perform the below steps to restart the print spooler : 1. Click Start>Run 2. Type services.msc 3. Click OK 4. A Window will pop up with so many services listed. 5. Scroll down to locate "print spooler" in the list, right click on it and click "Restart" 6. Restart the Computer. Once if you are done with steps, please connect the Printer and then Power ON Printer and check the issue. This should resolve the issue for you. If you need any further assistance on the issue, you can mail me at [email protected] . I'll be glad to help you. Bye.
SOURCE: DUPLEX PAPER JAM
I posted previously. After buying new paper, the duplex printing is working. It is probably heavier than my previous paper, but not particularly thick (don't know the exact grade.) So if you have this problem, try buying some new paper a little thicker than you are using now.
SOURCE: continual paper jam: canon mp830 - error 5100
follow the following:
As a technician, I have worked on tons of printers. This particular error had stumped me for a while, but I finally found the cause. As others had pointed out before, it can have alot to do with some obstruction in the print path, the gears, or ink on the clear plastic encoder strip. You're on the right track - I found the the purge cap (the white sliding mechanism that the print head parks to when it's not in use) was not lubricated well enough from factory. If you lubricate the sliders with some white grease (don't get it on the small wipers or the black caps) the mechanism can now slide more freely, and the unit can park the head properly without giving you the dreaded head homing error 5100 (or E-2-2 on the LCD display) Keep in mind that this repair will probably require you to remove the right panel off of the printer to gain access to the purge mechanism. There are two screws behind the printer, and two in front for each corrosponding side panel (the front screws are behind the grey front panel of the printer - open the top cover to see the clips which hold the front cover on) Hope this helps some of you out.
Thanks
SOURCE: Canon MP530 shows paper jam,
First – diagnose your problem. In my case the first roller
which feeds the paper through the ADF (under small black flip up cover on top)
was not turning. Hence no paper advance and error claimed a paper jam (it wasn’t
– just a failure to advance paper)
The cause turned out to be a stuck gear turning that silver
rod at the top. A bit of household oil has worked a charm.
To get at the gear, unhinge the ADF cover retaining tie
(black flexible plastic stopping it opening all the way). Just lift it up and
roll over towards printer.
Then unscrew one screw next to that tie. Gently prise
plastic cover off by lifting up from left hand side (near that black tie). It
should rotate off. Keep power on and fingers out.
Put a few drops of oil on top gear. Place paper in ADF and
attempt a batch scan operation. Gears should turn and lubricate parts. Repeat. Once working, replace cover, screw and tie.
Mine had seized months ago and is now working fine. Hope
yours does too.
P.S. Get a Continuous Ink System (as sold on eBay) - awesome for an ink guzzler...
SOURCE: my canon mx310 keeps showing a paper jam alarm and there is no paper jam. how do I fix it?
give this a try
alternative :
Load
a piece of thick paper, for example photo paper and press the resume
button (may be diffrent button on diffrent models) a few times to the
printer picks up the paper and puts it through the machine.
