Prime means.... pumping. In other words the water in the machine goes through a water pump. That pump, pumps the water from the fresh water container in your machine and pumps it up through the machine, then goes into a heating element that heats the water and then of course flows over the coffee or tea that you put in your machine to give you a nice cup of hot tea or coffee. Priming is in a sense getting the air out or allowing the water to start flowing. If you have a vapor lock or air lock, you need to prime it to kind of help this pump start pulling the water up to the coffee.
Hello, this is common. The pumps on these machines are not real good pressure. Sometimes you have to help it prime for the pump to work.
So one very good way to solve the problem is to turn the machine on and lift the water reservoir up just a couple of inches and then jam it back in place fast and hard. With this way is like it injects just enough pressure into the system to open the check valve and when the motor pump will run you will realize that immediately water will passing through from reservoir to brewer tank. This procedure has to be done often between cups.
From what we seen in internet their hundreds about the same problem but we have not see any serious response about it From Keurig's customer service yet.
One other important and related problem frequently reported is the irregulars doses of coffee like HALF-FILLED CUPS of coffee e.t.a
This must be redesign from Keuring factory since there is not much we can do about it to solve once for all even if they will replace your machine with a new one you will have the same problem in few weeks. And definitely this not a problem due your Electricity in your area or due to hard water. However hard water areas will face bigger and more intensive the above problem so one more suggestion is to descaling the machine every week this will help a lot.
If you find the above helpful please remember to vote for it Thanks Mike
Thanks so much Mike!
This is our second Keurig, and I almost cried when the first one finally slowed down then finally died an agonizing (for us) slow death. We immediately went out and purchased another Keurig, but we never had this problem (the "Prime") previously.
I truly appreciate your solution, and I too hope that Keurig will respond to its customers' issues with this product. A half cup of coffee early in the morning just isn't adequate!
Peg
Thanks Mike. This really helped. I was getting nervous
Thanks Mike... This to is my second one and never had this problem before and so far it works and if I have anymore problems they will be sending me a new one cause they sent me a replacement before and I will not take no for an answer cause I need my coffee.. Thanks again..
My Keurig just started to do the prime thing. I did what you suggeted and it worked like a charm! Thanks Mike
After reading some of these tips I reached into the water tank with the bulb from the turkey baster and suctioned the filter and voila! I feel like McGyver!
I am crazed trying to make a cup of coffee in a vacation rental with an unfamiliar Keurig.. Added some water to the little opening as advised. Had to repeat the process to turn it off, reseat the water tank firmly a couple of times before the magic happened. Now I am at peace. Thank you everyone for saving my mind.
If you have an air compressor, crank down the pressure to about 20 psi, grab a tube of some type to cover the intake hole and inject air into the intake. A Tube? A short section of 1/2 inch pipe cpvc or copper, or a female air tool connector (Thats what I used)
You could probably also use a Turkey Baster Syringe, The thing with the Ball on the end.
Mine sometimes gets an air bubble in the water line. Instead of slamming down the water tank I remove the water tank, turn it off and turn it upside down. This dislodges the bubble and then I don't worry about harming the water tank. It's call the Keurig Burp.
I truly appreciate your solution, and I hope that it works! Additionally, I too hope that Keurig will respond to its customers' issues with this product. A half cup of coffee early in the morning just isn't adequate!
Peg
SOURCE: my keurig coffee maker turns its self off, even
If you can also see there are a lot of inquiries about the same or similar problem. We have already investigate the matter and it is a design problem from Keurig and it not any much that you can do,
We have a tip at the link that it explains it some more
http://www.fixya.com/support/r5543433-keuring_coffee_maker_b60_b70
Moreover you can contact the keurig customer service which we here that they are more than happy to help you and in many cases they have replace the machines with no further question, you can try also since you are a customer with rights.
Good luck
SOURCE: my coffee maker shows PRIME
The pump is not getting water...slam the tank down or bang on the side of the unit...
Here is a tip that I wrote that will give you some things to try that will help you get your Keurig coffee brewer working again.
Keurig Coffee Brewer not making a full cup of Coffee
heatman101
SOURCE: What does PRIME mean on my Keurig coffee maker?
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
SOURCE: need parts list for ELITE B40 KEURIG coffee maker
Should be listed in your manual. If you need parts check this out.
This is actually an ebay store. They have any Keurig part you could possibly need! It's the only steady keurig part business operating right now. Prices are fair products are in great condition. Seller has 100% positive feedback with 100's of satisfied customers who voiced their opinions of them.
They have parts for Keurig B30 mini, B40 Elite, B60 Special Edition, B70 Platinum, and B77
http://www.igotsweetdeals.com or
http://stores.ebay.com/Igotsweetdeals
SOURCE: how do I prime a
Hello!
Priming instructions at the following article as well as additional instructions if you have trouble:
http://www.ehow.com/how_7577013_keurig-wont-prime.html
Hope this helps.
