I ahve the same problem! ANy solutions out there?
Try and remove power for few hours so that the processor resets, check if there is fault in the door switch as the error had come in, check for good pressure at the inlet, and possibility of any fault in the pump. It is best to take a full view of the functioning of the units to ensure that there are no errrors that feed back. Clean and reset.
Hello friend, I appreciate your inquiry!
Based off my understanding your dishwasher is displaying an error code of I30. An I30 error code means this could be an issue with your aqua control. I would suggest performing a reset on your dishwasher and you can do that by flipping the household circuit breaker off for at least ten minutes. If you continue to receive an I30 error code after the reset I would recommend having a professional technician out. This will help you avoid any unnecessary part purchases. Hopefully this information is helpful to you. -Matt
