SOURCE: stove is not getting hot or elements
sounds like you've lost one phase of your 240 volt power
SOURCE: cannot remove bottom oven element from wires
Three days before Christmas and electric range goes, it popped the breaker,after resetting, oven beeped continuously while flashing "F1" we followed the owners manual by lowering temp.setting to off after power was turned off, with no luck, owners manual that the electric control detected a fault condition, didn't have a problem till now.......eating cold slice deli turkey for a xmas is not my idea of a xmas feast...........any help would be great thanks Dave
SOURCE: Frigidale 10 years old stove bottom heating
Have 10 year old fridgidare elec.oven. Model no.FEF355ASE and both bake and broiler have stopped working have power and ohm's are good. Whats next ?
SOURCE: Lower burner element doesn't heat. Frigidaire
Hi you probably might just have an oven limit that is open
To test that you would set your oven do these tests:
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: My oven does not work. The stove top does work.
If
your electric oven is taking too long to heat or just not heating up
right, then check out this tip that will give more detail about your
problem.
Oven
Problems Electric Oven is Heating Slowly or Poorly
heatman101
