Sony VAIO VGC-RB38G PC Desktop Logo
Anonymous Posted on Sep 28, 2011
A friend of mine have a sony vaio vgc-rb38g desk top and she has a video card in her unit which was being used since purchase and it started giving her the message no input signal and the unit goes to power save mode and the moni8tor goes to sleep only after several time4s depowering the unit then you get video, but when you turn off the unit the same thi8ng , how could could i resolve this problem
Muntejaya Ginting
Level 3:
  • Master 10,422 Answers
  • Posted on Sep 29, 2011
Muntejaya Ginting
Master
Level 3:
Answers
10422
Questions
Helped
2468178
Points
19564
Please check your video card for dirty conection ports and has it cleaned . Retry your PC. If problem persist, your video card is defective and need for replacement.
Regards
I need 1440x900 drivers for a sony vaio vgc-rb38g
You can download the video and device drivers from the Sony WEB site.
Select your model notebook and the Windows drivers you require. Please click on this link to the Sony support WEB site :-
http://esupport.sony.com/US/perl/select-system.pl?PRODTYPE=1,24,72&DIRECTOR=DRIVER
How do i do the factory restore on my sony vaio?
Your VAIO® computer is not supplied with System or Application Recovery CDs. Use the VAIO Recovery Wizard utility to recover your computer's operating system and preinstalled software programs. For more information about the VAIO Recovery Wizard utility program: 1. Click Start from the Windows® taskbar, and then click Help and Support. 2. From the VAIO Help and Support Center, click VAIO Recovery Options. Your computer must have an active Internet connection to access the Sony online support Web site. Observe the proper safety precautions when you upgrade your Sony computer. See Before upgrading your computer.
I Have no motherboard diagram for my Sony Vaio VGC-RB38G
http://esupport.sony.com/perl/swu-list.pl?mdl=VGCRB38G
try that link, on left hand side of the page it says drivers and right under that is manuals specs and warranty. Should be able to find it in there someplace.
My Sony VGC RB38G keeps losing power. I suspect it is an intermitent proble with the power supply. What is the part number for a replacement PSU and where can I get one?
You can call or go online to get the power supply you need. I recommend Tigerdirect.com, pricewatch.com, or 3btech.net.
Go online to get the phone #, and call to make sure you get the right one.
2answers
Hard Drive Winds up a little then a sound like it
This is problem with your hard drive and it has been crashes .Might be problem with logic card .Its better format if its possible otherwise call vendor for repair.
2answers
Computer resets for no reason and screen is getting lines in it. It is a Sony Vaio VGC-RB38G.
if its rebooting -then it could be an overheating problem- make sure the fans are working
2answers
Connection from power to motherboard melted
hi,
psu burn? anyway maybe wrong voltage supply,you replace psu(power supply unit) but check voltage rating if 220 or 115 volt make sure on this if auto volt fine ,but if there is selector for 220/115 adjust to what volage you have.,i think some device may affected of short circuited,
if pwer supply is ok now,you can test your device
disconnect i.d.e cable of cd room,floopy,and hard disk.on figure 4d74a22.jpg
all ide cable must disconnect,then if you got other video card put on it,loosen screw,and detouched at backside the vga cable releasing two quick lock bolt in.replaced video card,plug in and swich on
observed if windows appear at start menu only your motherboard is fine,if not check memory card replaced if you have two one by one you can check it.
if you got to appear start menu put back your
ide cable on other devices such as floopy, hardisk and cd room.then swich on.
have a nice day just log in on fixya if there a problem,were here to help you.dont forget to rate me.thank's
Top Sony Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
