Remove the bowls by pushing in black button on the bottom front left of the bowl, pull the bowl up a little, then pull it forward and off. pull the auger off and the seal is opaque, cup shaped, and on the shaft. replace that, lube the edge with food safe lubricant (i.e. superlube), lube the large round bowl seal in the back and put it all back together. you may need a preventive maintenance kit installed as well, but that's a bit more involved
SOURCE: Bunn Ultra slushy machine has
black goo .. actualy syrop is leaking rom the bin and collecting in the machine.you nead to stip the machine and steam clean it . replase the seals for the auger and bin. and lubricate them with food grade lube during reasembly.. your not alone. hopefully there is no damage at the auger housings.
hope this helped
SOURCE: I have an Ultra 2 bunn slush machine. One hopper
make sure it's mixed properly. if there is toomuch water, it'll freeze solid. if the mix is too rich, ice will form on the outside of the bowls. you may also have a low refrigerant level.
Is it leaking from the front or the back, and do you need to change the shaft seals on the auger or the seals on the PAF unit?
