Hotpoint Ultima WF860 Front Load Washer Logo
Anonymous Posted on Sep 28, 2011
My hotpoint Ultima WT960 washing machine is diplaying the fault code F - 10 just after the eash cycle has started Do you know what this fault code means?
  • Anonymous Sep 28, 2011
    Thanks for your help.
Richard Roth
Level 3:
Top Expert:
  • Hotpoint Master 9,472 Answers
  • Posted on Sep 28, 2011
Richard Roth
Hotpoint Master
Level 3:
Top Expert:
Answers
9472
Questions
Helped
2628355
Points
28464
  • F10 - Pressure switch not sensing correctly
    Thanks for your help Richard
  • Richard Roth
    Richard Roth Sep 28, 2011
    Thank you for using FixYa.
    If you need anything in the future, please let me know.
Hotpont washing machine wt960 fo8 code m/c stop
I believe F08 Error code is for a Heater fault
Issue: During a wash cycle the programme pauses part way through.
4helpful
2answers
Code F-02 on hotpoint WT960
Check and clean the filter and drain hose. Make sure the hose isn't kinked.
My HOTPOINT ULTIMA WASHING MACHINE wt960 is very noisy on the spin cycles...is there a need for oiling or what else can I do..?
It could have an imbalnce in the drum because the load is uneven, or your machine could be uneven on the floor,, try checking for the level of your machine
I CANNOT READ THE INFORMATION ON THE LCD DISPLAY ON MY HOTPOINT WASHING MACHINE MODEL WT960 ULTIMA
some times in many m/c it has a code for the status of the m/c
i mean not complet words like F2 IT MEANS FOR REPAIR MAN THE FAULT NO 2
THANKS
3helpful
I have a Hotpoint ultima wt960 with f01 error can I fit the part
Hi
f01 means motor fault. remove motor and check the brushes. if ok then fault could either be motor or pcb which is faulty.
regards
My Hotpoint Ultima WT960 is in the middle of a program and on the rinse cycle and on the screen is flashing H2O the door is locked with my wool wash inside. What do I do.
Check the program that you have it set on for the wool cycle. Some washers have where you can "add water" in the rinse cycle. If yours has this feature, I would try that also.
4helpful
Hotpoint wt960
Full manual can be downloaded from this link
http://imagebank.indesitcompany.co.uk/brochures_online/pdf/Hotpoint/Laundry/ultima-7kg-lcd-wm-19505771900.pdf
Technical helpline will be able to tell you what F10 means
3answers
Wf860
may be the pressure switch, or the rubber tube up to the pressure switch blocked
1helpful
2answers
Hotpoint ultima wt960 washing machine noisy on spin
Bearings faulty or another fault this model suffers from is the concrete balance weight retaining bolts shake loose, if it is the bolts tighten up as soo as possible. Regards Advisor
Top Hotpoint Washing Machines Experts
vince
Paul Carew
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
