Try alt+F10 when windows boot.
else try restart your computer start tapping F8 once you see the advance boot options..go to repair my computer..select the language..then enter your user name and password..in recovery options go to factory image recovery.
Unlike
other laptops, Acer laptops integrate a computer management utility
called 'Acer eRecovery Management' to create backup of hard drive data,
create restore point, reinstall applications & drivers, and reset
Acer laptop to factory setting.
Step 1: Before starting your Acer laptop, ensure that there is no external storage device attached to it. Now start your laptop.
Step 2: Press 'Alt + F10' when the laptop starts booting, and wait for a moment while Windows loads the reset files.
Step 3: When 'Acer eRecovery Management' window appears, select 'Restore System from factory default' and click 'Next' to continue.
Step 4: Again click 'Next' to
reset your Acer laptop. This process will erase all data from your hard
disk and reset your Acer laptop to original factory settings.
Step 5: Click 'OK' in the notification window to begin the the resetting operation. Now wait while your Acer laptop is reset to factory settings.
Tips: You can also create a backup copy of your laptop data before factory reset. Simply click 'Backup' in 'Acer eRecovery Management' window.
If you have any other issue with your Acer laptop/desktop/Notebook, fget technical assistance at http://www.vtechsquad.com/acer-support/
SOURCE: Reset Acer Aspire One to factory settings--clean hard drive
You will have to order the erecovery cds from Acer to put it back to factory settings. They can about $40.00 to $50.00 dollars and they arrive about a week after you order them. Once you get them, you boot from cdrom and follow the instructions on the screen.
Go to Acer.com to order them.
SOURCE: acer aspire 6920 back to factory settings
on the first screen that says something like "F2 to enter BIOS" and "F12 to change boot order", hit F10 (maybe Alt+F10 or Ctrl+F10, not sure) and it should pull up the recovery console.. just read carefully, the only option there might be reformatting C:
SOURCE: restore a acer aspire 4330 back to factory settings
Follow these instructions carefully:
To start the recovery process:
1. Restart the system.
2. While the Acer logo is showing, press <Alt> + <F10> at the same time to
enter the recovery process.
3. Refer to the onscreen instructions to perform system recovery.
I copied the above from an Acer manual, and it works on my own system, which is not the same model as yours. But you must understand that this will basically restore your computer to the condition in which it was when you bought it, unpacked it from the box, and followed the instructions to set up a new computer.
This will give you your system back as if it were brandy new, but in most cases, anything you created, like DOCs, or XLS files, again … ANYthing you created since buying this computer, will also probably not be there any more.
You will have a pristine, clean as new, computer system.
Be careful, be absolutely sure this is what you want to do, and go ahead and do it.
-a.
SOURCE: How do I reset my Acer Aspire 5517 to the factory
click start menu, click all programs, look for Acer and click on it. Then click Acer E recovery. in a few seconds a window will come up. click the restore option in the left hand menu. You can restore to factory condition or restore windows and save your data. its all pretty much there in front of u. hope it helps u
Testimonial: "Thanks Robert...you are a lifesaver!!"
SOURCE: how can i reset my
turn on your machine then hit del b4 the system starts...go to bios setting and locate the "set to default setting"..if it doesn't help,follow these steps; (you need a flash drive to do this)
instructions:
1.Save any files or folders on your Acer Aspire One with flash drives. Drag and drop files onto the icon of your flash drive.
Consider what data you still need from your Acer Aspire One's hard drive. Save the files to an external USB device.
Restart the Acer Aspire One's operating system. Wait for the Acer logo to appear on the LCD screen.
Press the "Alt" and "F10" keys at the same time to bring up the recovery menu. Press "Enter."
Click "Next." Follow the prompts that appear on the screen to restore the operating system back to factory settings.
Use the drop-down boxes to select the time zone and language information for your Acer Aspire One. Restart the netbook when you are prompted to finish restoring the computer.
Connect the external USB device to your Acer Aspire One and transfer the data you saved earlier back to the netbook.
