Question about Nortel Business Series Terminal T7208 - digital phone
How to remove auto attendant recording on nortel t7208. i recorded a new message on the auto attendant but once it plays the new message the old message still shows up? how do i get this to go away?
    Problem Solver:
  • 16 Answers
The CCR tree is probably enabled. Are you using one digit options (press 1 for sales for example)?
Posted on Oct 01, 2011
  • Misty Oct 03, 2011
    Yes. We share office with another attorney and it says press 1 for office a & press 2 for office b. I have it set up to ring once and then the auto attendant kicks on with options. That way we don't answer the phone at all until the caller presses 1 or 2. However the old message when we had the phone ring is still on there and it starts as soon as the press 1 or press 2 message sounds.
  • Shawn Glass
    Shawn Glass Oct 04, 2011
    You probably recorded just the greeting under the AA option. You have to record the CCR tree part of it also. Its a pretty involved process not easily explained in this type of format.
SOURCE:
I want to delete an existing greeting message on the autoattendant. How do I do that?
Okay, it sounds like you're using a standard auto attendant greeting setup.
Try this:
Feature 983
Password: 1020000 (or whatever you have recorded for the password)
Select AA
Select Greeting
Select Greeting again
Enter 1 (for Greeting 1)
You can hit Play to ensure that you are listening to the correct greeting. If not, select another greeting by enter the number 2 for greeting.
Once you have found the greeting that you would like to erase, simply press record and let it record one or two seconds of silence. The greeting will be gone. Press OK to accept the new greeting (silence) and exit the system.
May 13, 2014 | NorStar Startalk Flash 2 Phone
How do you erase and change after hours greeting?dhalman
Call voicemail by pressing the Intercom button then dialing 777, when it answers login by dialing 99# followed by the password(default is 1234#) then press 9 for system features menu. Press 3 to choose Automated Attendant, the system prompts for the Auto Attendant number(1-4), start with Auto Attendant 1,if you do not know which one is being used by pressing 1. Press 2 to choose Night Menu, press 6 to change the Night Menu prompt. Lift the handset, press 1 to record your new Night Menu prompt using the handset, press 1 at the end of your recording. To listen to the new recording press 23, to immediately re-record press 21, to save the recording press *#. Press # to save all programming changes and activate new recording. Press *7 to return to system features menu or hang up to end programming session.
Changing the Auto Attendant prompt should be done when you are able to do a test call on each line to verify that you have changed the correct prompt(in your case after hours or by putting the system in After Hours mode manually to ensure the After Hours prompt is active) for each line being answered by the Auto Attendant. By default all lines are assigned to Auto Attendant 1, if your system has been modified to use a different Auto Attendant for some or all lines, you will need to repeat the above procedure for the Auto Attendant being used. If at any time you get lost or confused while in the voicemail programming, hang up and start over. Once you get comfortable with navigating the voicemail programming, it gets easier. If you have trouble send a comment, I will try to help.
Feb 10, 2011 | Lucent PARTNER18 Corded Phone
T7316 Change recording of Company Directory
To re-record the main greeting on most Nortel voicemails, enter Feature 983. if your system has 2 digit intercom #s your default password is 120000 if your system has 3 digit intercom #s your default password is 1020000. once you have entered the password you will see 3 selections you can make .use the three soft keys under the display and select AA (auto Attendant). next press greeting and greeting again. next it'll ask for the greeting number your probably working with greeting 1. press record to start and ok when finished. dont forget to save the greeting or it will be deleted if you exit early. hang up when finished.
Jun 07, 2010 | NorStar T7316E Corded Phone
I have a Nortel T7208 phone. It shows "Message fo...
I have a Nortel T7208 phone. It shows "message for you" and the light is on but when I open my vm. I don not have a message how do I get rid of this?
May 19, 2010 | Lands Phones
Nortel 7316e: Need to change the auto attendant
To enter viocemail administration, press Feature 983. if your system has 2 digit intercom #s your password is 120000 if your system has 3 digit intercom #s your password is 1020000. once you have entered the password you will see 3 selections you can make .use the three soft keys under the display and select AA (auto Attendant). next press greeting and greeting again. next it'll ask for the greeting number your probably working with greeting 1. press record to start and ok when finished. dont forget to save the greeting or it will be deleted if you exit early. hang up when finished
Oct 27, 2009 | Nortel T7316E 2-Line Corded Phone
Cannot change greeting when we are out of office. M7310 phone
Which greeting is it? If the AA greeting...try this.
But listen before you record, to make sure you are recording the correct thing.
http://dstech1.com/how-do-i-change-the-auto-attendant-greeting-on-my-nortel-voicemail/
Jul 06, 2009 | NorStar M7310 Corded Phone
T7208 nortel network general voicemail locked
Generally, you dial feature 981 to get in, then extension number and password. If you have no new messages it will say that, then give you the option to review old messages. To delete a message you press 76. If that doesn't work, login to your mailbox, press 8* then 6 to get to "go to message" then press the message number and #. If you have an on-site administrator, they can delete your mailbox as well, otherwise you will have to call your tech help service and have them erase it remotely.
Jan 21, 2009 | Nortel Business Series Terminal T7208 -...
I do not want mailbox selection as part of recorded message
I'm no expert, but I have had a lot of trial and error experience with this set. Is your Auto Attendant on? This feature is designed to be like an operator for multi mailboxes. If it is, turn Auto Attendant off and record the greeting for mailbox 1. Hope this helps!
Dec 23, 2008 | Siemens Gigaset 8825 Cordless Phone
Enable Custom Messages
It's hard to see what you recorded the custom messages on, since you left that part out.
I'm guessing that whatever you recorded the messages on has a manual. Try reading it. Is your day greeting a custom message or is it one of the 32 announcements? However you play that message, you need to either replace it, or assign a new message or mode to the auto attendant.
Carl
Aug 25, 2008 | Panasonic KX-T7453 Corded Phone
Recording a new voice mail
feature 981
mailbox - last 4 digits of phone # then press#
password then press #
mailbox commands press 8*
maibox option 2
Apr 30, 2008 | NorStar T7208 Telephone
Nortel Business Series Terminal T7208 - digital phone Logo
577 people viewed this question
Top Nortel Computers & Internet Experts
J John
Vuk B
Are you a Nortel Computer and Internet Expert? Answer questions, earn points and help others
