Start your laptop before booting windows press f8 button continuously
If you are running Safe Mode because you cannot get into Windows, you may want to first try
loading the last known good configuration. To
get into the Windows 2000 / XP Safe mode, as the computer is booting
press and hold your "F8 Key" which should bring up the "Windows Advanced
Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key. Note:
With some computers, if you press and hold a key as the computer is
booting you will get a stuck key message. If this occurs, instead of
pressing and holding the "F8 key", tap the "F8 key" continuously until
you get the startup menu. Trouble Getting into Windows 2000 or Windows XP Safe mode
- If after several attempts you are unable to get into Windows 2000 or
Windows XP Safe Mode as the computer is booting into Windows, turn off
your computer. When the computer is turned on the next time Windows
should notice that the computer did not successfully boot and give you
the Safe Mode screen. Windows Advanced Options Menu Safe Mode Enable Boot Logging Start Windows Normally Use the up and down arrow keys to move the highlight to your choice. Once
you're done in Safe mode if you want to get back into Normal Windows
restart the computer like you normally would and let it boot normally. Click here to get additional information about getting out of Safe mode. Microsoft Windows Vista and Windows 7 users
get into the Windows Vista and Windows 7 Safe Mode, as the computer is
booting press and hold your "F8 Key" which should bring up the "Windows
Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key. Note:
With some computers if you press and hold a key as the computer is
you get the startup menu. Trouble Getting into Safe mode
- If after several attempts you are unable to get into Safe Mode as the
computer is booting into Windows, turn off your computer. When the
computer is turned on the next time Windows should notice that the
computer did not successfully boot and give you the Safe Mode screen.
ndows 2000 / XP users
Please select an option:
Safe Mode with Networking
Safe Mode with Command Prompt
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Reboot
Return to OS Choices Menu
I had installed a new harddrive to my Compaq Presario desktop with windows 7 but I had windows vista installed already. I'm still unable to install windows 7. I'm getting an error 0xc000000f.
Plz check the virus go to safe mode & uninstall the virus
SOURCE: My home Pc wont boot up at all in safe mode or
hit F8 repeatedly at startup to go to safe mode, then try and re-install drivers.
