How can I get my Jacuzzi elongated toilet to fill faster? Are the fill valves adjustable somehow? I have already checked the water source and hose and connectors, all are very good.
After flush the system must close the hole which lets water into the toilet. If it does not close after flush, it is continuously letting the water thru. Check if it closes after flush and allows tank to fill.
Check to see if there is not a clog in the trap. This could keep your bowl from filling up. Also check the flapper and see if it is staying afloat in the tank long enough during the flush. Either of these could be the cause here.
The fill valve sounds if it is bad.Go to lowe's and get a fluidmaster fill valve(about $8) instructions included.turn off water and remove water from tank then disconnect supply tube,remove old fill valve install new,follow installation diagram,and the adjustment process to adjust the water level to correct level that should take care of your problem.
sounds like you may have debris in your lines. I was not aware of this until recently but, you should drain your water heater once a year to get rid of sediments that linger and travel through your lines causing possible blockage problems.
Try turning your water valve off. Flush toilet so there is no water in the toilet or tank. Unscrew your line to shut off valve to make sure there's no debris.
Good Luck!
look inside the reservoir. There is a cylinder sticking up at about water level or above. That cylinder should have a small hose (tube) going into the top of it attached with a small clip. This helps fill the bowl with water. These come off from time to time and just fall down into the water and dont do what they are supposed to do. Hopefully this is the problem.
The water level in the bowl is determined by the built in trap in the back of the bowl. Water is allowed to enter the toilet and it then "over flows" the p trap in the back when flushed. Once it's flowing, it syphons the water out of the bowl. While the tank is re-filling, a small portion of water should be running down the overflow from the small hose clamped onto the overflow This rinses the inside of the bowl, as well as helps-refill the bowl. Be sure that hose is directed inside the overflow tube. To see what the max water level in the bowl can be, add some water from a cup or glass. Once it's full you can keep adding and it won't get any higher. This will be the max level you can expect.
