when the clean light flashes its displaying a fault code based on the number of times it flashes...if it flashes 7 times then pauses then flashes 7 times again its displaying error code#7 if 4 times then pause its code#4 ect.
This tip i wrote will tell ya how to reset the board since sometimes its just electrical anomilie..reset the board and if it again flashes let me know how many times in a row it flashes and i will determine which error code it is , heres that tip to reset the control board http://www1.fixya.com/support/r10357661-get_whirlpool_dishwasher_start_when
GENE
Yeah. It was blinking 7 times. I did that reset code. That did something, it sounded like it ran for a few seconds, stopped, and now the four hour delay light is flashing.
OK thanks...the #7 error codes means that the part called the flowmeter is bad,Is water entering the tub in sufficent amounts?? if yes the water level seems to be entering the tub and is at or aboutthe level of the heat element the water leve is good but the flowmeter didnt detect it entering the dishwasher,and the flowmeter would need to be replaced.
You can try once again resetting the board to see if ya can clear the delayed start it ya cant reset it ya may need to let it run the delay then start after 4 hours.
This is what the flow meter looks like
It is what the water entersinto the tub from the left side wall and to replace it the dishwasher would need to be pulled out.
Reply once more and i will give the part number for it
