Question about ViewSonic PJ551 Multimedia Projector
How do i access the air filter on the PJ551? - ViewSonic PJ551 Multimedia Projector
  • 488 Answers
Air-Filter
Cleaning the Air Filter
The air filter should be cleaned as described below at intervals of approximately 100 hours. When
the filter is used for approximately 100 hours, the message "CLEAN THE AIR FILTER" appears
when the projector is switched on.
1 Switch the projector power supply OFF, and remove the power cord from the power outlet.
2 Clean the air filter with a vacuum cleaner.
3 Reset the Filter Timer using the function of the FILTER TIME on the OPTION Menu. Please
refer to the description of the "FILTER TIME" on the Table 9: MAIN Menu.
Replacing the Air Filter
Replace the air filter if contamination cannot be removed, or if it is damaged. To order a new air
filter see page 26 for contact information.
1 Switch the projector power OFF, and remove the power cord from the power outlet.
2 Remove the filter cover and the filter.
3 Replace the new air-filter and the filter cover.
4 Reset the Filter Timer using the function of the FILTER TIME on the OPTION Menu. Refer to
the description of the "FILTER TIME" on Table 9: MAIN Menu.
Posted on Sep 27, 2011
  • Lawrence Brown
    Lawrence Brown Sep 27, 2011
    I can provide you with the manual which also has pictures if you need more assistance. LBrown18062@hotmail.com Please include PJ551 Manual in the subject line. Hope that this information is helpful to you. Lawrence Brown
  • Lawrence Brown
    I have done further research and was able to send you the Service Manual with a direct location of the filter which should enable you to better access it. I hope that this is enough to get you going in the right direction. Lawrence Brown
SOURCE:
My PJ551 M. Projector is blinking red for LAMP and Temp? What can the prob. be?
This always happens on hitachi projectors aswell,It is just meaning that you need to clean the air vent and reset the timer and then it should be alright.
May 07, 2010 | ViewSonic PJ551 Multimedia Projector
Ghost image in different color from main image - text appears "doubled"
Use the remote to access the menu and you'll be able to POSITION the colors horizontally and vertically .
You should be able to align with the other colors to make it sync'd.
Dec 16, 2009 | ViewSonic PJ551 Multimedia Projector
View sonic projector
Go to menu and choose option. Then choose lamp time or filter time, depending which one you want to reset and keep pressing reset-button for 3 seconds
Jul 23, 2008 | ViewSonic PJ551 Multimedia Projector
Both Temp and Lamp lights blink red
All you should need to do is go to the menu on the projector, and find the Filter Timer. Hit the right arrow to select the filter time, and then hold the rest button on the projector until you are prompted to confirm the reset. Hit menu to confirm and it should now reset the filter timer. Now cut the projector off and back on and the lights should stop blinking. I hope this helps.
May 23, 2008 | ViewSonic PJ551 Multimedia Projector
Not able to reset filter timer on ViewSonic
HI there
Scroll down to the filter timer in the Menu and hold down the right arrow button for a couple of seconds .
Apr 10, 2008 | ViewSonic PJ551 Multimedia Projector
Yellow Image
Hi there
You could if you can get your hands on the LCD's.
BUT if you have never done this before , don't try it at all. It is not as simple as all the other parts in the unit to replace !
Apr 03, 2008 | ViewSonic PJ551 Multimedia Projector
Viewsonic Projector Blue Vertical Line
Hi guys
This is a common Mainboard problem on Projectors , unfortunately the Board will either need repairing or replacing.
No shortcutts on this one !
Aug 12, 2007 | ViewSonic PJ551 Multimedia Projector
ViewSonic PJ551 Multimedia Projector Logo
2,238 people viewed this question
Top ViewSonic Office Equipment & Supplies Experts
jasbo
jasbo
Joaquim Martins
Are you a ViewSonic Office Equipment and Supply Expert? Answer questions, earn points and help others
