Question about HP PL4260N 42 in. Plasma HDTV
I replaced the module on YSUS board and replaced the FS2 fuse on hp cptoh-0602 plazma tv. TV worked great for about 2 hrs of usage time. however, while i was changing the channal few days later since repair, i heard the small pop and the picture went out again. I checked the FS2 fuse on YSUS board and it is out again. Any idea what else could be the problem? Thank you for your time and help.
Usually, when you replace Y-sustain board, for older plasma, they suggest to replace both Ydrive board (up and low). And sometimes, Z-sustaint.
Im not sure your are an expertise in this matter so be very careful when you open a TV because hasardous voltages can kill you in the worst escenario.
If you are not, don't work on your TV. It will be your sole responsibility.
Check ships on Y drive board (both board are installed on the right side of Y-sustain. They have square black ships that used to get bad. If they don't have aluminum cooler on them, you can see if they are burned or have holes on them. Old plasmas use to have issues with those boards. Before you installed the Y Sustain you should check Ydrive boards. Maybe you damage the Y Sustain because the Y drives weren't good.
Try to replace the fuse, disconnect the Ydrive from Y Sustain, turn on TV and check for voltages on Y sustain (panel has a sticker with each voltage). Hope you didn't damage Y sustain and can find Ydrive board to fix your TV.
And REMEMBER, you can kill yourself when you work on TVs.
Posted on Oct 21, 2011
6ya staff
SOURCE:
Hi! I have a 2006 HP High Def Plasma TV model CPTOH-0602, serial CNH6131576. It lost picture, I can hear sound. Wonder what couls be the problem?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent.
Dec 09, 2014 | HP Televison & Video
Picture just went out on my tv but I still have sound
I have the same problem with my HP PL4260N 42" Plasma HDTV serial # CNH6141988, model # CPTOH-0602. I have perfect sound and can change channels still with sound but NO PICTURE. I am a consumer with a question that need the advise of an expert.
Apr 17, 2013 | HP PL4260N 42 in. Plasma HDTV
Picture went black but you could still hear the movie
Hi- My PL4260N stopped working after about three years, the audio worked but no video at all. The TV worked fine until one day...no more picture.
I found out that the YSUS and ZSUS boards in the TC fail alot...BUT you can get new or repaired ones off of EBAY...
First check for failed components (burned, loose, bulging, etc.) if nothing obvious is failed then check the fuses on the YSUS, ZSUS, and power supply boards...usually if a board has a blown fuse the board needs to be replaced...get the part number and search it in Google and eBay and you will find options for replace/repair.
Mine had a blown fuse on the YSUS board...I got it fixed for $75 through coppell TV (they are on Ebay)....
Now my TV works fine again!
Good luck.
Dec 19, 2010 | HP PL4260N 42 in. Plasma HDTV
Lg plazma tv du-42x12x/12xc picture went after loud"pop" when set was turned on.
hi there.most likely the fuse on the ysus panel has failed,which is the board on the left,looking at it from the back.if the fuse has failed,then so has the board...quite a common fault with all lg plasmas...
Sep 11, 2010 | Televison & Video
My hp plasma tv lost it's picture. Audio works fine. Work are some causes of this?
The T-con board, the board that sit right in the middle of the center LCD panel . That board is dying. try websites like shopjimmy.com, Ebay.com to buy a refurbish T-con board for replacement.
Thanks for using fixya
Aug 20, 2010 | HP PL4260N 42 in. Plasma HDTV
LG TV screen problem
I have Lg 29" color tv.and now the screen display size is getting increased(wider) . so the image(video) is getting pixyoursnavin.jpgelated. and also channel logos are cutting off from the screen./,,........ please let me know wats the problem and how to solve it .......
Jun 06, 2010 | LG 42PX5D 42 in. Plasma HDTV
My picture is flickering but there the sound is
Did you try buying a new HDMI cable? You can also try some of the solutions in the post called "Hp 42 plasma tv cptoh 0602 I get sound but no picture."
Dec 31, 2009 | HP PL4260N 42 in. Plasma HDTV
I had the same problem today, Hp wanted $629+tax to fix. With a little mechanical ablity anyone can fix this.
1. remove back covers
2. left-hand side is the video board
3. two white fuses
4. replace
this fixed mine and they only cost $1.50 each
Aug 25, 2008 | HP PL4260N 42 in. Plasma HDTV
HP PL4260N 42 in. Plasma HDTV Logo
597 people viewed this question
Top HP Televison & Video Experts
Ekse
Thomas F. Schneider
Edward Easley
Edward Easley
Are you a HP Televison and Video Expert? Answer questions, earn points and help others
