1997 Kia Sportage Logo
Posted on Sep 26, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a 97 kia sportage with 160,000.miles ,stick shift, ......when shifting from 4th to 5th its hard to get into 5th and ill put in 3rd my mistake...is this a ezay fix ?
Anonymous
Level 2:
Sergeant:
Champion:
  • Expert 288 Answers
  • Posted on Sep 26, 2011
Anonymous
Expert
Level 2:
Sergeant:
Champion:
Answers
288
Questions
0
Helped
65775
Points
766
Sounds like ther is a selector problem in the gear box. Take off the top, where the gear lever goes in and have a look. if there is anything wrong there the box will have to come out.
Masalah camshaft tak di pasang dengan betul
hi dear, kia sportage 1997, when drive a car between 60 to 80k/m grear is not shift 3rd to 4th, some time work some not work & rpm going up & down. please tell me what need to do. thanks
answer..
need to check or replaced the temperature thermostat and sensor.
2answers
Car jerks when shifting down when slowing down to a stop..mainly from 2nd to 3rd gear or 3rd to 4th gear
Most likely yuor transmission. But you can check the sensors with a scanner
1999 Kia -Sportage manual will not shift into 3rd or 4th You can drive it by shifting from 1st to 2nd and then to 5th
your trannny is suffering internal damage... you will have to take it to a shop that services tranny to find out exactly whats going wrong with it... but its not the clucth if your wondering it can be either the syncros going bad or the shift selecter etc....advise taking it into a shop and getting service
I just replaced all the belts on my 2000 Kia
The last shift is not a real gear shift, it is called "torque converter". The high rpms happens because the transm. goes to neutral. Get it to a transm. shop to be tested
Why won't my 1997 ford aspire shift into 3rd or5th
it could be the valve body sticking, or worn clutch plates in the 3 & 4th gear planetary drum, or 3rd &4th gear solenoid is bad
Won't go into gear to drive. may be transmission?
If the clutch has never been changed most likely it is that. The way you can check it is by removing the transmission and looking at the clutch disc. It could be transmission syncros but I am willing to bet you just need a new clutch.
Top Kia Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you a Kia Expert? Answer questions, earn points and help others
