Casio FX-115ES Scientific Calculator Logo
Anonymous Posted on Sep 26, 2011
Convert -525 degrees into radain pi form - Casio FX-115ES Scientific Calculator
k24674
Level 3:
  • Casio Master 8,093 Answers
  • Posted on Sep 26, 2011
k24674
Casio Master
Level 3:
Answers
8093
Questions
0
Helped
4671848
Points
21595
Here is some help
180deg is equivalent to Pi radians
Take some angle. Its measure in degrees is say x_deg, Its measure expressed in radians is x_rad.
The fraction of 180 deg that the angle represents is equal to the fraction of PI that this angle represents.
Conclusion: the ratio x_deg/ 180 deg must be equal to the ratio of x_rad/PI
x_deg/180 deg=x_rad/PI
Isolate X-rad in the above equation. Some will tell you to cross multiply.
x_rad=(Pi/180)*x_deg
Application: x_deg=-525 in radians?
x_rad= (PI/180)*(-525)=-(525/180)*PI
Keep the value (525/180) as a fraction reduced to its simplest form. The result is 35/12
How do I convert arcsin radians to arcsin degrees?
180 degrees =PI radians
1 degree=PI/180 rad
1 rad =180/Pi
Cannot convert my calculator from degrees to radian mode.
Learn the equivalence.
180 deg=pi RADIANS.
1 DEG= (Pi/180) rad.
1 rad= (180/Pi) degrees.
How to draw a trig function (y=sin(theta)) on a Casio 9750 gii
The variable theta is reserved for polar plots. So if you want to graph functions of the form y= expression, you must use the default variable x. Thus draw y=sin(X). Make sure your calculator is configured with the correct angle unit (degree or radian).
If you use degrees the window dimensions for x must cover an interval of 360 degrees, to have a full period. If angle unit is radian, then choose an x-interval between [-pi and pi] or between [0 and 2pi]
How do I convert any decimal into a fraction?? ex: sin45 is 0.8509035245 (press which buttons to make a fraction)
Not all decimal representations have equivalent fractions. Take pi. Its approximate value as given by the Casio FX9750II is 3.141592654. This is just an approximation because the string of decimal digits in pi has no end. It continues . Such a number that cannot be represented by a ratio of two integers is not rational, not a fraction. It is called irrational.Other such numbers are ?2, ?3,?5, e the base of natural logarithms.
As a matter of principle, if a number is called irrational, it is because it is not rational (not a fraction), and it makes no sense to try to cast it into fraction form.
However, if you truncate an irrational number so as to keep only a finite number of decimal digits, then that truncated number can be represented by a fraction, but qualitatively speaking, it is not the original irrational number.
Thus if you decide to use 3.141500000000000000....0 as an approximate value of pi then you write
3.1415=31415/10000 and the calculator will convert it to the mixed fraction 3u283u2000. To effect this conversion, you press the [FD] key to the right of [a b/c]. If you want an improper fraction 6283u2000 you press [SHIFT][[FD].
As to the value of sin 45 you quote, you should be aware that it is valid for an angle unit in radians.
It is an approximation because the radian unit is based on the value of pi, which, as I said above, is an irrational number.
If you use the degree angle unit, sin45 deg is actually equal to 1/?2 or ?2/2 and this is clearly irrational, and it cannot be represented as a fraction. In conclusion it makes no sense to try to cast it into such form.
On the other hand, sin 30 deg or cos 60 deg are both exactly equal to 1/2. The calculator will convert them to a fraction.
On a more general note, the calculator will always be able to convert a fraction into an approximate decimal number, but the converse may not be possible. It depends on the number of display space available on the screen.
Convert degrees to radians
One half circle,
To convert from degrees to radians, divide by 180 and multiply with pi.
3helpful
How do i convert degrees to radians?
There is no built-in conversion for this. The simplest way to do this is to multiply by pi and divide by 180 (or divide by 180 and multiply by pi). If you have to do this often, you can store the constant pi/180 (or 180/pi) in memory and use that instead of doing the calculation again and again.
8helpful
4answers
How can i enter a polar form number with angle to convert into a rect form
how can i enter a polar form number with angle to convert into a complex numbe(a+bi)
4helpful
How do I get from degrees to radians? For some reason my TI-84 will not convert degrees to radians.
Press the [MODE] key to access the mode comfiguration screen .
Set angle unit to to radian (see above)
Enter angle value in Decimal degrees only, use the [2nd][ANGLE] key sequence to have access to the degree symbol. The degree symbol must imperatively appear at the end of the angle value.
Here are some examples
If you use angle values in DMS, it will not be converted to radians, but to decimal degrees.
If you omit the degree symbol there is no conversion.
A general formula is Pi radians =180 degrees
6helpful
How to convert fraction to decimal
You can convert between Standard Form (with fractions and pi) or Decimal form by using the "S<->D" button. Use Mode 1 if you mostly prefer fraction answers and you can use the SD button to convert to decimal or use Mode 2 if you mostly prefer decimal answers and use the SD button to see the fraction.
I hope this helps and good luck!
Please remember to vote 51218db.jpg Thanks.
Trigometric circular functions..
No the calculator cannot do that.
But if you do [2nd][Pi] [EXE] then just after [2nd][tan-1][2nd][Ans] you get 1. If you use the inverse trigonometric functions you will never have a value such as pi/4 or pi or pi/2. If angle unit is set to degrees you recover the exact values of the angles (they are integers anyway.
Hope it helps.
Top Casio Office Equipment & Supplies Experts
k24674
Arnie Burke
Arnie Burke
Ngoro
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
