Your problem is that you are not using a suitable memory card for the D90. 2Gb SD cards have read/write speeds that are much too slow to work with quality DSLR's. Let me explain. When you take a picture with the D90, the data generated first goes into a small capacity buffer memory. The purpose of the buffer is to act as a conduit to your SD memory card and retain picture data until all of the data is safely written to the SD card. If your SD card can accept data as quickly as the buffer can pass it to the SD card, there is no problem. But, If the SD card is not capable of accepting the data quickly enough, the buffer will start to fill up since data is coming in faster than it is going out. If you take pictures in quick succession with a slow SD card or if you shoot video with a slow SD card, the buffer will overflow; i.e., fill to its capacity and become incapable of accepting more data until its capacity returns as the SD card accepts the data. During that time, the camera will prevent you from taking any more still photographs. You will push the shutter release and nothing will happen. If you are shooting video, the camera will continue to work, but the sound will loose sync with the picture.
For your D90 to function properly under all conditions, you must have an SDHC card that is rated at 45Mbs or faster. When I first bought my D90 several years back, 35Mbs was the fastest card made and I had the problems I described to you above. When Sandisk brought out the Sandisk Pro card with a 45Mbs speed my problems melted away. I should also ad that 2Gb is much too low of a capacity for the D90. It will fill up very quickly if you shoot Raw or fine quality jpeg files. You need a minimum of 8Gb.
SOURCE: reformatting an SD memory cardf
You can format the card in your camera while not connected to your computer. In fact it's recommended to do so. Read your instruction book to find out how. It should be a selection available from your "menu" button when in image review mode. Select "low-level" or "full" format, not "quick" format (quick format is only good for erasing pictures).
SOURCE: sd memory card not read by computer
Reformat the card from the camera. You didn't specify camera model but every digital camera has a menu to format media.
If you don't succeed try to connect your camera to the computer and read the photos.
If that doesn't succeed either take your camera to service.
SOURCE: I bought a 2GB SD card for my Kodak EasyShare C330 Camera
Buy a 1GB card (or 2). The spec for the SD card format is going to 2GB but the Kodak C330 not compatible with 2 GB SD memory cards.
Click
After having the same trouble, I installed a 1 gb card and it worked just fine. It appears the Kodak C330 won't recognize a 2 gb car.
SOURCE: Nikon Camera is not saving pic's in memory card
go into the camera settings and check the storage selection..
it may have internal memory as well as the card
