There is a small circuit breaker on the underside of the machine back in the general area of where the AC cord attached to your machine. reset breaker, make sure your tray is in place and the clear cover is put in the down position. should turn on. if not the transformer is most likely blown Westco Laminating Service 405-324-6092
GBC appear to just be a crappy company. I have a Heatseal H212, same problem. Worked fine then one day when I turned it on it never became "ready". I waited a while longer then turned it off.. except it wouldn't let me turn it off. I had to unplug it from the mains to get it off. After that, it would never turn on. Checked the fuse, it was fine.
SOURCE: I have a gbc heatseal
There is a small 125 v 10 amp fuse in the circuitry on the right inside the unit. Whether or not this will solve your issue is unknown. I have one apart in front of me right now with other problems.
Check the fuse.
Where is the 3 amp fuse locadid
