Microsoft Office Professional 2007 Full Version for PC Logo
Anonymous Posted on Sep 26, 2011
Wants to give random page number in ms word - Microsoft Office Professional 2007 Full Version for PC
Tally Girl
Level 3:
  • Master 1,134 Answers
  • Posted on Oct 12, 2011
Tally Girl
Master
Level 3:
Answers
1134
Questions
0
Helped
398649
Points
2496
Not too sure whether your comment above is the problem or what you want to do.
Do you want to insert a page number, then put in non word doc pages, then have the next page in your word document numbered appropriately? If so, you need to insert a section break at the end of the page where you are going to put in pages, then make sure the page layout for the second section does not have "different first page" turned on. Now break any link between section 2 and section 1 in the page layout. So click off the "same as previous" icon in the footer in section 2. Then insert a new page number and set it to "start at" the page number you need it to be.
If you need several sections like this then just repeat the process.
Remember that if you delete a section break, then all the page formatting will revert to that in the previous section. Horrible but its what Word does. Go to the end of any document with sections and add one section break at the end of your text with the same page formatting as you want through the pages before you remove any section breaks in the document to avoid this.
There is a really good e-newsletter on Office issues, Woody's Office Watch; if you use Office a lot but find some features difficult to master, you'll love WOW, very helpful.
2answers
Ms publisher printing
Using the most current print drivers. Try this site
How do I generate a random number that is greater than 1 on a casio fx-300MS
The random number function always generates a number between zero and one. You can convert this to a random number in any range by a suitable combination of multiplications and additions. For example, if you want a random number between zero and ten, multiply the generated random number by 10. If you want a random number between one and ten, multiply the generated random number by 9 and then add 1.
If you want to simulate the roll of a six-sided die, multiply the generated random number by 6, add 1, and ignore the fractional portion. This will give you a 1, 2, 3, 4, 5, or 6 with more-or-less equal probability.
3helpful
Drivers for MSI-7021
on this page:
http://www.msi.com/service/search/?kw=ms-7021&type=product
Select your model name, and click to download(MS-7021 is model number, on motherboard is inscribed and the model name).
If I could be offurther assistance, let me know. If this helps or solves the issue, please rateit and give a testimonial for my response.
2answers
I cant seem to find any Ethernet drivers for my MSI MS-6590 can u give me some link for it, some softpedia or something?
MS-6590 is model number. On the motherboard must be inscribed also a model name.
on this page, select your model name:
http://www.msi.com/service/search/?kw=MS-6590&type=product.
Ms 7236
On this page:\
http://www.msi.com/service/search/?kw=ms-7236&type=product
Select your motherboard model name (MS-7236 is model number).
2helpful
Msi ms 7267 driver
on this page:
http://www.msi.com/service/search/?kw=ms-7267&type=product
select your model and go to download page.
5helpful
I have a casio fx9750GA plus and need to know how to generate random numbers. I have had a quick look at users manual but can't find it. Can you help?
The following uses keystrokes and screen captures from the FX-9750GII but the essential information is the same. Use the F6 key to move to next page of TABS (those at the bottom of screen) until you find the TAB that interests you (PROB, RAND#, INT, etc.)
The random number generator function is called Ran# and can be accessed in RUN mode by pressing:
[OPTN] [F6] [F3] (PROB) [F4] to access the (Ran#) function
In the paragraph above, the bold text in square brackets indicates key presses, while the text in parentheses represents the menus that appear at the bottom of the calculator screen. This also assumes there are no menus on the bottom of the screen when you begin. If PROB is already on the screen, then the [F6] key is not necessary, just press [F3] then [F4] at this point.
The Ran# function generates a random decimal number between 0 and 1. If you need to generate a number with a higher range, then there may be extra steps involved. For example, to choose a random number between 0 and 100, you would enter:
Ran#×100 or Ran#(100)
Let's say you want to simulate a dice roll, where you get an integer between 1 and 6. Your first step would be to do:
Ran#×6
This will give you a random decimal number between 0 and 6. But we need an integer, not a decimal. To make it an integer, you would change this to:
Int(Ran#×6)
Press [OPTN] [F6] [F4] (NUM) [F2] to access the (Int)
This now gives you an integer between 0 and 5. We just need to add 1 to the result.
Int(Ran#×6)+1
The result should be an integer between 1 and 6.
3answers
How do I get it to print the page numbers
What SOFTWARE are you using to print from? MS Word? What OS do you have?
1helpful
Ran#
A random number generator exists on this calculator. It is accessible in RUN or PGRM modes by pressing the OPTN key. If you don not see a tab PROB at the bottom of screen, press the rightmost key to move to next page.
Anyway, RAND# generates a real number between 0 and 1.
For other numbers read on.
Ran#×6
Int(Ran#×6)
[OPTN].......(NUM) [F2] to access the (Int)
Int(Ran#×6)+1
How to delete page numbers from manuscript?
It depends on which text-editing program you are using.
Check "page setup" within NOTEPAD -- it adds page-numbers when printing.
In MS Word, check "Headers and Footers" to exclude page-numbers.
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
