SOURCE: Can the batteries be changed in Britain?
of course you can just pop into any jewellers or watch shop they will fit it for a small fee
SOURCE: Steinhausen watch adjustment?
To set time, you need to unscrew crown anti-clockwise direction if you have a screw-in crown watch. You need to softly and slowly pull the crown out a little bit. The best way to do this is to use first and second finger and use finger knuckle as a lever in order to pull the crown out with as little force as possible. You can feel a little "click"! Now you can set the time by turning it anti-clockwise. This would turn the minute-hour hands forward until you set the right time. When time is set, push the button back and screw the crown clockwise for a few rounds to ensure it is screwed back tight.
SOURCE: how do I set time and date on my automatic Steinhausen watch?
you can refer to the customer service on the Steinhausen
homepage:
http://www.steinhausenonline.com or call free: 24/7(800)208-2607. they can offer you the best advice.
SOURCE: New quartz analogue watch losing 5 minutes a day.
not often so . beleive you me from an avid fine watch collector . it's the batteries. hopt this helps.
SOURCE: How do I remove the
Your watch has a press down caseback, you need to get a knife or watch caseback knife and look for the depression ot notch on the edge of the caseback, slide your knife up tight to the notch and pop the knife edge up like a lever, the caseback should pop off.
