SOURCE: Broken heaphone jack inside desktop
Contact manufacturer of computer. If you have a warranty they should be able to help you with the problem.
SOURCE: Broken headphone jack
you should be able to get it out from the inside on the card. Do you have a sound card or is your sound on the motherboard?
SOURCE: can't get headphone jack on front of computer to work
The headphone jack up front may not be connected to the PC's integrated audio on the motherboard (or to the PC's sound card if you purchased one with the system instead. There'll be an audio cable running from the front of the computer to a port on the motherboard. If you look at this motherboard diagram for the Vostro 220 (not the 420 or 220s), it'll be the port numbered "15" that's the opne for the audio for the front panel. You don't need the speakers plugged on the back to have the headphones work, but having them plugged in will at least tell you if the sound is working or not.
SOURCE: Computer speakers do not work on new Dell computer
Check Bios settings to be sure audio is enabled, then go to control panel, click on sounds, and make sure sound is not muted
SOURCE: Rear headphone jack is not working!
Go into the case and unplug the frount headphone jack to enable the rear, some motherboards are particular on this issue.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
