The F06 is a drive motor tachometer failure which means the motor control is not able to see the motor is running. This can be a difficult problem to pin down, but there are some things you can do yourself if you like. Check the connections between the motor control and motor. Also check connections on the central control are all tight. Push on all of the connections and see if there is any improvement. The images below will help with access on some Maytag front load washers.
Image 1
Image 2
Thank you for the response. I did check all the connections and went as far as performing the diagnostics test that was in the tech sheets supplied inside the cabinet. I'm quessing that the MCU is bad and ordered one. Hopefully this will cure the problem.
