The hum is generally attributed to the compressor trying to start- being intermittent suggests it is failing and going into a delay via an internal safety switch. Assuming this and the fan you speak of is the condenser fan there are 2 good diagnoses- either the run capacitor is bad or the compressor is locked up. I would change the capacitor and install a hard-start capacitor, if the problem persists it would most likely require a new compressor.
Yes, you almost always have a fan which blows air through the ducts. The condenser fan is one which is located on the condenser moving air across the coils to transfer heat. This is present almost always with the exception of water source (geothermal) units. Can you confirm the presence of a condenser fan and if it's running or that the unit is geothermal?
thanks for you insights.
p.s. I thought my unit has only one fan. Can a unit have a fan + a condenser fan?
