SOURCE: I have a Lenovo 3000
What about removing the hard drive from the laptop and put it into sata box, to be USB external drive.
And then get out your important data, and format the hard disk.
and try again to boot???
If it doesn't work , try to replace the memory it might be the problem with the memory.
SOURCE: I have a IBM Lenovo ThinkPad T61. My laptop had
Even if you replace the CPU now, You will still need to replace the defective fan.
SOURCE: Blank screen upon startup
Try taking out the hard disk, plug in power and see if you have a display on your screen or external monitor. if same thing happen, try taking out the memory card. If you hear a beep sound it's a faulty mem. card, if no beep sound appears I suspected it's a motherboard faulty.
SOURCE: IBM T61 remains with dark blank screen but is on.
Connect it to another monitor,and see if it comes on. Your screen may be damaged.
