The TV may not have the programming to be set all the channels, what you need is a channel converter for TV, you will connect the CoAX cable (from the cable provider) onto the converter and then the converter will be connected to your TV will have all the channel for you. You will use two remotes though one for the TV and one for the converter.
you can check this out http://www.sz-wholesale.com/Search-Result/TV-CHANNEL-CONVERTER/
Just for reference
Try to see if it has the ability to go to UHF, sounds like it's stuck on VHF. There may be a switch on the unit somewhere. It may be written as an AIR/CABLE switch instead of VHF/UHF.
Its problem of Tuner, old tuners didn't have ability of Hyper band frequency so it receives less channels on cable. Ask local tv repairman to replace its tuner with new Hyper Band tuner.
Your old tv does not have more than 11 slots to store channel .
Thats why you are not able to get more than 11 channels .
But let me confirm it .
SAM ANDERSON
I do get other channels but they not coming in clear-I do get other channels clearly. When I called comcast (my cable provider) I was told I needed to get a code to allow my set to receive the other channels.
