Insert the pen drive into USB port, then open My Computer. You will see some drives. Hard disk drives, CD Room drives, and removable media drives. Example: Your hard disk (drive C, D, E), CD Room (drive F), Removable media (drive G). So, each time you insert a tool such as pen drives, memory cards, etc, you can see it on drive G.
To view the data pen drive, double click My Computer, click the drive G. If you want to move files from pen drive to your hard disk, open the drive G, block all files, copy and paste to drive C / D / E.
hopefully help
USB drives can be write-protected by modifying the StoreageDevicePolicies Registry key and WriteProtect Registry value.
click Start>run>regedit to open Registry Editor. and press control+F to open the find dialogue box and type "usb device" or "driverdesc" to open usb mass storage device or type "usb mass storage device" in the search windows. And right click on it and delete. This will set the policy value to 0. then insert your usb device. It will work fine.
# Remember: do not delete any unknow files in the registry as this will make some programes not work as usual.
also
If you are running a Windows XP OS then you might be able to:
- click start right click on my computer select open
- Right click the icon of your Flash Drive (It should be F:/ or something)
- Click Properties in the menu that comes up
- Click the Sharing tab
- Click permissions
- And finally, click Allow next to Full Control.
hope this helps
don
