Sears Genie Garage Door Gpwk12 Wireless Keypad Compatible with 9 or 12 Dip Switch Genie Max Openers Logo
Anonymous Posted on May 04, 2017
I just installed a Sears Craftsman 1/2 HP Garage Door opener. As I was doing the adjustment to keep the door closed, it closed too tight. I disengaged and confirmed the door arm was set wrong so I fixed it. I tried to re-engage by running the opener but it just hums now :( - the Cable side is dangerously tight and the motor unit won't release the tension, and the chain is sagging on the other side of the chain spreader. Is there anyway to release the tension on the Motor unit manually? Or is there maybe another solution to my problem?
Lawrence Oravetz
Level 3:
  • Sears Master 10,558 Answers
  • Posted on May 04, 2017
Lawrence Oravetz
Sears Master
Level 3:
Answers
10558
Questions
Helped
2700312
Points
29284
Use the emergency release handle to release the door. Run the opener to the open position until it stops. Close the door until it stops. Now re engage the the door.
1 Related Answer
Anonymous
  • 3197 Answers
  • Posted on Sep 26, 2011
SOURCE: I just installed a Sears Craftsman 1/2 HP Garage
Pull down on the manual release rope. It may be hard to pull.
Craftsman 1/3 hp garage door opener I bought a new one - my father installed it and the door will open half way - that is it.. then when you go to close it - it closes and then opens half way...
I hate to say this but it sounds like your father did not follow the instructions when he installed the opener. Try following these instructions.
Loosen the chain enough so that you can remove it from the sprocket above the motor unit. With the door closed run the motor until the sprocket turns clockwise and stops. With everything attached replace and tighten the chain. Some adjusting of the up and down limits will probably be required.
Garage door doesn't open and close properly
3helpful
I just installed a sears craftsman 1/2 hp garage door opener. when i close the garage door with the remote the chain track bends up just about 12 inches before it closes all the way, and this only happens...
What is wrong is you need to adjust the limit on the door when it comes up. What it is doing is coming to far back on the track. You need to push the back limit forward away from the motor so the door does not come back and drop down on the inside of the garage. The opener is trying to push the door up hill to get it to close that is why you are getting the bend in the track.
Good Luck
1helpful
2answers
Garage door opened, won't close
If you can press and hold the wall button and the door will go down, you have a photo eye issue. Check the photo eyes at the bottom of the door.
Door wont close all the way
NOT SURE WHAT UNIT YOU HAVE .
ALL OPENERS HAVE AN ADJUSTMENT TO TELL IT HOW FAR TO GO UP AND HOW FAR TO GO DOWN. LOOK ON THE SIDE OR UNDER A LIGHT COVER.IT HAS TO BE THERE SOMEWHERE
2answers
Craftsman 1/2 hp door opener
replace the logic board
http://www.chamberlain-garage-door-openers.com/circuitboardcompatibilitychart.htm
Top Sears Building Materials Experts
hsapiens
Level 1 Expert
Are you a Sears Building Material Expert? Answer questions, earn points and help others
