Question about Archos 504 500870 Digital Media Player
My 504 Archos will not turn on. I have just charged the battery fully. It was working earlier on half charged battery.
  • deniselouisa Sep 25, 2011
    Thanks Ezrahite,
    It worked, you are great.
    President:
  • 1,607 Answers
Problem already solved. Please accept Ezrahite's solution.
Posted on Sep 25, 2011
  • 2,632 Answers
Welcome to Fixya. Press the Reset button on the inside of the unit with the battery removed. This should solve the Problem. If not you may need to send it in for repair just make sure you check the warranty of the unit.
Reset button is located under the battery. So remove the battery and look for the button at the end of the archos where the battery pins make contact. To the right of those and half way down between the pins and the case of the hard drive will be a gold round looking circuit. this is the reset. Press it and off you go.
Please let me know what happen. This is the only work around that you can do to fix the issue. The reset button will restore the archos to its original factory settings.
Thanks
  • 1 more comment
  • Rofel Lantican
    Rofel Lantican Sep 25, 2011
    Hi - if you can ready this and it worked can you please accept my solution so that the payment will be credited to my name because it was locked to another expert. Thanks
  • Rofel Lantican
    If you will not accept my solution the credit will go to the person who has the solution 1. On your email you will see there accept solution. Thanks
  • Rofel Lantican
    Rofel Lantican Sep 27, 2011
    Hi - please accept my solution if i were able to fix the issue. Thanks
SOURCE:
Archos 504 dysfunction
Did you try to reset the device? Turn off the Archos, remove the battery. Near the 2.5" hard disk you will see a small golden button. Press it with the tip of a pen during 10 seconds. Put the battery back and turn on the device. Maybe it helps.
Jun 25, 2010 | Archos 504 500870 Digital Media Player
My archos 504 will not charge the battery . how much is a new battery
You can get one in www.newmp3technology.com for 22€ aprox.They are Archos providers,and the large life of their batteries are well tested.
Feb 05, 2010 | Archos 504 500870 Digital Media Player
Unit crashes then will not restart after being unresponsive.
After removing the battery, I discovered a small brass reset button, about 3 mm in diameter, near the battery connection terminal. This was gently pressed with a pen for 15 seconds. After refitting the battery, the unit was fully functional again. This reset results in needing to set the clock again. No other settings are affected.
Jan 08, 2010 | Archos 504 500870 Digital Media Player
Archos 504 comes on when plugged in briefly but no charge
I had the exact same problem, I looked a bit on the net and I found the answer. What you have to do is push the reset button when your archos isn't plugged on. The reset button is located behind the battery ( you'll have to the remove the battery ) near the pins that connects the archos to its battery. It looks like a gold circle and if you push it you'll see it's a button. After pushing the reset button try to put the battery on back again and replug your archos, it should work normally now.
Good luck !
May 12, 2009 | Archos 504 500870 Digital Media Player
My Archos 504 will not power up.
Press the Reset button on the inside of the unit with the battery removed. This should solve the Problem. If not you may need to send it in.
Reset button is located under the battery. So remove the battery and loo for the button at the end of the archos where the battery pins make contact. To the right of those and half way down between the pins and the case of the hard drive will be a gold round looking circuit. this is the reset. Press it and off you go.
Thanks,
Ed
Dec 23, 2008 | Archos 504 500870 Digital Media Player
Archos 504 RESET button
Please open Battery cover and PRess Small Golden button just near the HDD , it will restart the Devie
Jul 21, 2008 | Archos 504 500870 Digital Media Player
Archos 504
does the archos come from europe and you are in the US, my point is if it is off say ebay theit will be set up for 240v and therefore is shall we say starved of power.
Mar 17, 2008 | Archos 504 500870 Digital Media Player
Bless you guys...!
I thook the chance n press the reset button....Nuthing has been erased from my hard drive!!! :D :D :D
Nov 16, 2007 | Archos 504 500870 Digital Media Player
Archos 504
I had a similar problem remove the battery and push the gold coloured reset button. It worked on mine, You don't lose any info doing this. I got the advice from the Archos support phone number CC
Aug 19, 2007 | Archos 504 500870 Digital Media Player
Playback button problems
please check what is your firmware version, the latest one is 1.6.23. If it is lower please upodate it by downloading the file from archos website. Maybe it would help
Jun 07, 2007 | Archos 504 500870 Digital Media Player
Archos 504 500870 Digital Media Player Logo
Top Archos Audio Players & Recorders Experts
Marvin
Marvin
 Grubhead
Grubhead
 Mike M
Mike M
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
