SOURCE: Polaroid DRA-01601A will not power up
these units are famous for capasitors popping in the power supplies.
SOURCE: Polaroid Will NOT edit out Commercials!
I have a Polaroid DRM-2001G w/80 GB hard drive. After recording a program or movie on my DVR, I use the "Segment" feature and go back thru the program or movie and take out the commercials by hitting the "OK" button on my remote. It's very simple to do. It doesn't edit perfectly but I don't have to watch the commercials if I burn it to a DVD.
SOURCE: Polaroid DRA-01601A Hard Drive Model/Format
The HDD is 160 gigs.
The menu allows one to "format" the drive.
I have not tried this however.
SOURCE: i have the polaroid dra-01601a dvd/hdd audio
Polaroid DVD / Recorder DRA-01601A, refurbished machine with password. How do I change password or get default password. Unable to delete HDD programs without it unless I format HDD each time.
SOURCE: password problem
The password is for the parental control feature.
For the Poaroid dra-01601a the password is 3-3-0-8 type this in using the number pad then press ok. If you press setup on the remote then press down till you get to ATV/DTV then press right arrow button to highlight DTV Parental control, press enter then a dialogue box will appear this is where you can input the password code. Select V Chip and press ok, you will then have the option to select which content controls to use in the menu you will see Block enable, use the down arrow to highlight this then press the right and left buttons to turn either on or off. to exit this setup press 6.
Hope this helps,
James
Testimonial: "THANK YOU THANK YOU. I KNOW IT WAS SIMPLE INFORMATION BUT I SURE COULDN'T FIND IT. I SPENT TWO HOURS ON THE USELESS MANUAL AND INTERNET. GREAT SERVICE"
