Dryers Logo
David Parsons Posted on Sep 24, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Frigidaire Affinity dryer (mod# AEQ6000ES2) turns on but drum will only turn for a few seconds then stop. What could be the problem and can I fix this myself?
Anonymous
Level 3:
  • Frigidaire Master 43,501 Answers
  • Posted on Sep 26, 2011
Anonymous
Frigidaire Master
Level 3:
Answers
43501
Questions
0
Helped
10835118
Points
101584
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
1helpful
My dryer (Frigidaire Affinity)just stopped working as if the power shut off.. I have checked the breaker, it's fine. it stopped in the middle of a drying cycle. I'm thinking the control panel went out
http://www.appliancepartspros.com/repair-help/frigidaire-dryer-aeq6000es2-repair/aeq6000es2-wont-start.html
Take a look at this web page/video. Your problem may be that the thermal limiter switch blew (which is not that easy to replace) .... compared to something in the control panel going out. Had you been doing a lot of heavy dryer loads before the unit died .. or a lot of lint built up? A blown limiter switch in some dryers will be as if you unplugged it (nothing goes on) ... but some dryers will still turn the drum but not heat. I am not sure about your unit.
The limiter switch is a safety device so your dryer does not overheat .... so if the switch did blow try to understand WHY .... or it may just blow again.
Good luck...
Jan 02, 2018 • Dryers
Why can't I get my new control board for my Frigidaire affinity dryer to work?
Hey tim bryant, thanks for your post!
I understand that you have installed a new board inside of your Frigidaire dryer, AEQ6000ES2, and on the new board the lights blink. I would recommend a reset on your appliance which can be done by disconnecting the power to it for roughly ten minutes. If that step does not correct the issue I would seek professional assistance for the repair of your dryer. I hope that is helpful. -Matt
The belt is broken i have a new one i need to know how to get inside the dryer
Hi Cyndy s
Go to the following webpage and watch the video on how to dissassemble your Fridgidaire Affinity Dryer this is for the front slide replacement but you will remove the drum and you will see where the belt goes.
http://www.youtube.com/watch?v=yIPnnUqJ6Ds
For parts and a schematic of your dryer.
http://www.appliancepartspros.com/parts-for-frigidaire-aeq6000es2.html
If the belt is broken and you don't know how to route the belt check out the following picture
Please rate me
Bud
My dryer quit working this morning. The light and beep go off but the drum dies nothing.
I have the Frigidaire Affinity Washer and Dryer. A few weeks ago my Washer door switch went out I changes that with no problem. Now the Dryer has just stop quit working. Here are the symptoms on the ; 1>it's plug up and the power is fine 2> there is no errors on the panel 3> control operate fine. 4> close the door, set the controls, press start, No spinning. 5> when you press start you hear a buzzing sound for about 5 seconds, then nothing... Is it over for the dryer I bought 3 years with out extended warranty, or is the a simple fix? Thanks, Rob...
1helpful
Affinity aeq6000es2. After two cycles of the
sounds like your heating element opened up,as it was running and when the element broke it arced and these were the sparks you saw,you will need a new heater element
Frigidaire Dryer Error E 04
I have the same problem. Does anyone have an answer?
LED display on dryer reads AD???
All this is doing is letting you know that the Auto dry sensors are kicked in and checking to see how dry the clothing is.
1helpful
Frigidaire affinity dryer problem
the thermistor in air outlet duct is very common for these. with front panel off find plastic duct from blower at bottom. pull out thermistor and look at inner side. it has triangular shape and if you can see shiny redish color at tip instead of all black then its worn. this causes numerous heat and control issues.
Top Frigidaire Dryers Experts
ZJ Limited
ZJ Limited
Paul Bade
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
