Jura Capresso Impressa Z5 Espresso/Coffee Maker Logo
Anonymous Posted on Sep 24, 2011
Z5 asks to add tablet after adding tablet....
Anonymous
Level 2:
Scholar:
  • Expert 115 Answers
  • Posted on Sep 24, 2011
Anonymous
Expert
Level 2:
Scholar:
Answers
115
Questions
0
Helped
86416
Points
218
Hi, after you have put the tablet in, press the rince button to continue the cleaning process. Dazza REPAIRER
Can add memory be added by adding another chip to ZTE tablet
I would check ZTE's website to be sure, but if there is an empty memory socket inside the tablet for expanding memory, then it's possible. Adding memory to the SD card slot on the side of the tablet does not increase tablet memory to run programs, only for making more room to store pictures from the camera.
How can i get my pad to show home page
http://www.dummies.com/how-to/content/how-to-reset-ipad-settings.html How to Reset iPad Settings Life may not have a reset feature, but iPads do. If, for some reason, you want to return your iPad to its default settings, you can reset them. The last item under iPad's General settings is Reset. When you click it, you get options for resetting the following:
  • Reset All Settings: Every one of the preferences and settings are reset, though information you've added to apps like Calendar and Contacts doesn't change at all.
  • Erase All Content and Settings: This one both resets your settings and erases information you've added to apps like Calendar and Contacts. This is useful if you plan to sell your iPad.
  • Reset Network Settings: By choosing this, any networks you've set up are removed. iPad will also turn off Wi-Fi, and then turn it on again, which disconnects you from any network you're connected to. Note that the Ask to Join Networks setting stays on.
  • Reset Keyboard Dictionary: When you turn down iPad suggestions of words as you type, you can add words to the keyboard dictionary. You do this by tapping a suggested word, which rejects it but adds the current spelling of the word to the dictionary. If you don't want to keep all those added words, use this reset option.
  • Reset Home Screen Layout: If you want to get back to the original home screen you saw when you took iPad out of its box, choose this reset option.
  • Reset Location Warnings: When you use an app like Maps that checks your location, it asks you if it's okay to do that. When you tap OK to let it proceed two times, it stops asking. If you want it to start asking again, tap this reset option.
1helpful
5answers
Where do you add a tablet to the Jura Impressa Z5
Decalsifying tablets are diluted in the water. Cleaning tablet is added in the Ground coffee area.
1helpful
Water in disposed coffee container jura impressa z5
You may have to clean the unit using cleaning tablets, also there is a flap in the bay (remove the tray and use flashlight, sometimes it cakes up and moisture collects. Final thought is you may need to send it in to Capresso/Jura for service. Mike
1helpful
Cleaning cycle
The flap of the funnel has a piece of plastic that sticks out, which pushes on a microswitch under the top cover.. If the funnel is not seated correctly, it will not work the microswitch.. This will also apply if you try to use it with ground coffee.
There are 2 switches side by side, the other is for the bean hopper cover.
I suppose you could insert a small stick into the hole, and press towards the front of the machine.. it should have a distinctive click to it. if it works, then either the plastic piece on the ground coffee cover is broken, or the funnel is not seated correctly.. if it doesnt work, you need a new switch fitting.
5helpful
Stuck in cleaning mode?
Open the preground coffee lid, drop a cleaning tablet in it, let it do it's tablet cleaning cycle. After cycle empty water out of tray and clean.
1helpful
Impressa E8: even though I did clean machine, it asks me again...
Make sure your water tank to fill, when you start the clean process, and the tray is empty and wiped down. Then add a 500ml container under the spout rather than let the water go into the tray.
Also if you have not serviced the machine for about 5,000 cups this can occur.
Connection to my computer
UMS mode allows the Z5 to interface to the computer as if it were a removable hard drive. You can then use Windows File Explorer to manage the files in the Z5.
To get into UMS mode, connect the Z5 to the USB port while simultaneously holding down the "return" button (the top of the square keypad) while connecting. This will put the player into UMS mode for that connection period only.
If you upgrade to the new firmware, you have the option of making it always connect in UMS mode.
The steps to install the latest firmware are:
(1) Download version 2.37 or newest of the Z5 firmware http://www.samsung.com.
(2) Unzip it to get the file named "Z5Update.dat".
(3) Disconnect the Z5 from the USB port.
(4) Reconnect the Z5 to the USB port while simultaneously holding down the "return" button (the top of the square keypad) while connecting. This will put the player into UMS mode for that connection period only.
(5) Open a File Explorer window, and find the YP-Z5 device.
(6) At this point, make sure the Z5 is fully charged and has at least 30MBytes of free space.
(7) Copy the file "Z5Update.dat" to the root directory of the YP-Z5 device.
(8) Now disconnect the Z5 from the USB port.
(9) The Z5 will display the option to upgrade to the new software, or to cancel.
(10) Select "Upgrade". This will power off the Z5.
(11) Connect the USB cable to the Z5. Now it will upgrade the firmware under USB power. DO NOT DISCONNECT THE USB UNTIL THE UPGRADE FINISHES. After finishing the upgrade, new firmware will be started automatically.
(12) Check the version information in the "Settings > System Info > Version" tab.
Now you can turn on the UMS only option.
Settings / System Info / UMS Only = On
Doodles1
Top Jura Capresso Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
Sulejman Sulejmani
Sulejman Sulejmani
Grand Canyon Tech
Grand Canyon Tech
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
