Question about Lanier 1205 Copier
Lanier copier 7313 AG
When making copies, copies come out as if the paper was slid down the page. I asked you guys a month ago and was told the registration clutch needed replacing. Any idea how much this costs and where there is a dealer or repair person in our area. Our area Fisherville On Canada N0A 1G0
  • Lanier Expert
  • 422 Answers
The clutches arnt too bad putting them in however... I own this model as a home copier but parts are hard to come by and to get a tech that knows how to repair is harder.
Posted on Jun 22, 2009
  • 48 Answers
The going rate for lanier service is around 125-150.00 per hour plus parts.
clutch is probably around 90 bucks. Lanier Dealers and Ricoh dealers are all over the world. Google the nearest branch
Posted on Oct 18, 2009
SOURCE:
Lanier 6613 copier. Image is offset down the page by 3 and 1/2 inches. Is this a setup issue? Any suggestions?
try making a copy and then open the door when the paper is in the center of the machine. if the image is offset before the paper hits the fuser(hot) rollers>the problem is in your drum unit (most likely a cleaning blade. If it happens after going through the fuser(hot) rollers you have a fuser roller problem. Most likely you have a worn drum cleaning blade which is cheaper the a drum. Good Luck.
Dec 17, 2010 | Lanier Office Equipment & Supplies
The copies on our Lanier/7313 come out zebra stripped. The copies appear to copy better if we change the copy darkness to a lighter color.
Zebra striping is typically caused by a bad development clutch. Most likely, the developer and the development clutch will need to be replaced, but the 7313 is so old you may have trouble finding parts, or finding a technician to work on the machine.
Sep 21, 2010 | Lanier 1205 Copier
How do I reolace the toner in a lanier 7313 copier.
It was very easy. I just had not seen the machine when I posted the question. Thanks
Jan 07, 2010 | Lanier 1205 Copier
How do you enter simulation mode and the code when you replace developer on lanier 7313.
Press C00C or C interupt key 0 interupt key and 41 for developer counter display 42 for developer counter clear 46 for exposure level adjustment 72 for maintenance preset counter setting 25 for automatic developer adjustment. 40 for developer preset counter display.
Nov 10, 2009 | Lanier Office Equipment & Supplies
Inappropriate spots of ink on copies
You might try setting the machine for card stock, this will slow the machine down therefore heating the toner better on the thicker paper.
Sep 22, 2009 | Office Equipment & Supplies
I have a Lanier 7313 Copier which doesn't copy properly. Even with a new ink cartridge, the copies come out faded. Any ideas on what I can do?
This machine goes through developer pretty quickly. Sounds to me like it needs new developer and possibly a drum (and drum blade).
Aug 24, 2009 | Office Equipment & Supplies
Lanier 6725 copier: Paper is always jamming and
I have worked for Lanier for 20 years, the 6725 was a great machine, but getting parts, spending $$$ and still having an old copier. Lanier is owned by Ricoh and all machines are Ricoh with a Lanier sticker on it. Its time.
-Carl, please let me know if this helps.
Jun 26, 2009 | Office Equipment & Supplies
LANIER COPIER 7313
I guess by your fault description that there is a blank gap before the printing starts? The only way to cure this problem is to replace the registration clutch as it is turning on too late and not releasing the paper quick enough. Also check that the paper tray dial is displaying the correct paper size and position.
Thanks Jason
Aug 15, 2008 | Office Equipment & Supplies
Lanier 7320 - Makes only all black copies
Was the toner bottle removed before you moved the machine?
Jun 09, 2008 | Office Equipment & Supplies
Copies from multiple trays
No, you will have to put your paper like you want( one sheet white and one sheet yellow and so on ) and put it in the same tray !
Mar 25, 2008 | Lanier 1205 Copier
361 people viewed this question
Top Lanier Office Equipment & Supplies Experts
quennie732
Adorjani Laszlo
gggg
Are you a Lanier Office Equipment and Supply Expert? Answer questions, earn points and help others
