Question about Yukon Optics
Yukon 2.5 x50 nvrs tactical night vision rifle scope, works fine but making a strange processing noise when on?
    Master:
  • 577 Answers
Hello, don't worry about it. It is HV to the image intensifier tube. The battery voltage goes through control circuit then to ccfl inverter (here is were dc voltage is switch on and off and switch dc voltage is step up by toroid coil that has two input and only two out puts). By impulsing the coil with two different switch dc voltage on the input this make the current lag the two different phase voltage by 90 degrees. Here is where the strange noise is coming from. The toroid coil is encased in iron case and if half of this iron case is loose, it makes case vibrate so the noise.
Now, the voltage come out of the toroid coil is switching dc (one could call it AC because that what AC voltage is, it switch between positive to negative) this voltage is about 300 to 900 switching DC voltage. This voltage will be applied to a 1/2 wave voltage multiplier (this voltage multiplier with have anywhere four four stages to 10 stages depend on what the input voltage to multiplier is.
Low the voltage out of the ccfl inverter the more stages the multiplier will have.
Now, the voltage multiplier will double the voltage per stage to need image intensifier tube voltage of 12000 to 45000 volts---DC switching or AC what ever one wants to call it. This voltage will bit you but it doesn't have a lot current associated with it, the current would be in the 10 to 15 ua (micro-amps) 1/10X6 amps.
Now, you know. GB...stewbison
Posted on Sep 24, 2011
SOURCE:
I am Looking for the manual for the D-141M Night Vision Rifle Scope.
Hello, go to Night Optics web site and contact them through their web page. stewbison
Dec 24, 2010 | Kalinka Dipol D-141 Russian Night Vision...
I have a AMT nightvision rifle scope that was made in the 1990's that has no serial numbers. I am wanting to know more about the scope. what generation etc.
Hello, AMT is defunked, no more, all gone, left in the night, can't see them. no good bye. Don't worry, ATN Inc bought their stuff, just different name now. Sorry, i don't think you can find any material about the AMT NightStorm NV. Try contacting ATN Inc. in CA. ATN does make NightStorm monoculars. GB....stewbison
Nov 18, 2010 | AMT NightStorm Night Vision Optics The...
Extended viewing distance when fitting a external i/r flashlight and his it worth fitting a rifle scope adapter ,what viewingdistance will be lost with or without it thaks trilby
well its a gen "1" unit so any extra "ir" light will help out a lot! i use a deban gun light 50 watt buld with an "ir" filtter fitted to the light i can see nearly 1/2 mile and i can just about target a rabbit at no more than 100m with my sight set at x5,,,(3-9x50 with a 30mm bore) there not all there cracked up to be,,you loos a lot of light going through the scope,
to have a good night sight you need to go to gen 3!!!! so you need to sell your sole to buy one!!!
Jul 06, 2010 | Yukon NVMT 2x24 Gen 1
The power is on but when i look though the scope it is blank
hit the reset, take the batteries out for 10 minutes so it resets, if that doesnt work you have to mess with the contrast.
Sep 13, 2009 | Vision Optics Atn Aries 330 Warrior Night...
Name of scope . Yukon . Problem : I tried to replace a battery in the dark. Removed the wrong part by relative force . Scope damaged. Two tubes on the front of the scope one is the battery tube and th
I would strip the wires as carefully as I could and get them back together, get the 2 AA batteries back in there, and see what happens. Then go about making a permanent splice in the wires and getting the lens to stay on there, or ship it back to Russia for repairs. Or find somebody to do it. I'm sure it can be done. Hope this helps.
May 24, 2009 | Zhumell Yukon NVRS Titanium 2.5x42 Night...
Optics Logo
349 people viewed this question
Top Yukon Optics Experts
Marvin
Marvin
John Porter
Bill Boyd
Are you a Yukon Optic Expert? Answer questions, earn points and help others
