Kenwood KDC-MP232 CD Player Logo
Anonymous Posted on Sep 24, 2011
I need to know which pin is for what - Kenwood KDC-MP232 CD Player
Che Que
Level 1:
New Friend:
Problem Solver:
  • Contributor 13 Answers
  • Posted on Sep 24, 2011
Che Que
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
13
Questions
0
Helped
996
Points
25
Hi...try and check this site, there are lots of pdf about Kenwood KDC-MP232 CD Player...http://search.4shared.com/q/50/kenwood
1helpful
Need a new power supply for a soyo mother board Crown model fp-
All you need to know is if your motherboard has a 24-pin or 20-pin power connector. You can just count the pins if you don't know. There connector is located on the motherboard. It looks like this: moondogwst75_3.jpg
So if it's a 24-pin, order a 24-pin power supply. If it's 20-pin, order 20-pin. Hope this helps!
3helpful
2answers
I forgot my pin number and master key please help
In the System Settings Menu, go to the 3rd page, then select "PARENTAL CONTROLS."
  • Select "YES," to change the parental controls.
  • You will be prompted for your 4-digit PIN.
    If you know the PIN, select the empty text box and enter the PIN using the on-screen keyboard, then select "OK" to continue.
    If you don't know the PIN, select "I forgot," then select the empty text box for the answer to the secret question and enter it using the on-screen keyboard. Select "OK" to continue.
    If you don't know either the PIN or the secret question, the Parental Controls will need to be reset.
    An Enquiry Number will be displayed. Ring the number given in the Nintendo DSi Operations Manual and provide the Enquiry Number. You will then be issued with a Master Key. Tap "OK" and enter the Master Key. Tap "OK".
  • Select "PIN" to change the PIN or "CHANGE SETTINGS" to update the setting you wish to change. Once the changes are made, select "DONE" to confirm any changes.
"If you don't know either the PIN or the secret question, the Parental Controls will need to be reset. Please call 1-800-255-3700 for assistance."
I wan to know my atm pin number
There is no way I can pluck this out of thin air.
You need to contact your bank and get them to reset your ATM pin number, then you need to change it straight away so you are the only one that knows your PIN number.
Record your PIN number and keep it in a safe place, if someone knows your PIN they can empty your bank account.
1helpful
How can i know the pin # of 8100
Go to options, status, and your pin should be there.
I need to know the exact pin numbers to power on a toshiba mk4004gah
If it's a SATA drive, the power connector is the longer one. Pins 1-3 are 3.3v Pins 4-6 and 10-12 are common, Pins 7-9 are 5v, and Pins 12-15 are 12v. If its a IDE drive, the power connection uses a molex connector. Yellow (pin 1) is 12v, Red (pin4) is 5v, Black (pins 2,3) are Ground (common).
Gigaset 8825 cordless phone pin reset
The default PIN for base and handsets is 0000 - if it has not been changed
  • Press Menu on Handset
  • Scroll to Mobile Settings - press ok
  • Scroll to Local Settings - press ok
  • Scroll to Chang Pin - press ok
  • Enter Current handset PIN - press ok
  • Enter New PIN - press ok
  • Display will show Confirm - Reenter PIN - press ok
Need help on a 4 pin rk56 to a deltaforce
Shield & red to pin 1
White to pin 2
Blue to pin 3
Black to pin 4
1helpful
Motherboard
To download you're manual for the D815EEA2, please click the link below.
ftp://download.intel.com/support/motherboards/desktop/D815EEA2/EA2FV_English.pdf
You need to go to page 85.
7482c11.jpg Starting at Pin 1 (Hard drive LED) is positive + & pin 3 is ground -. Next, Power LED, Pin 2 is + & pin 4 is ground - .
Letter C, is for the reset switch, Pin 5 is + & pin 7 is - .
Power on/off switch, pin 6 is + & pin 8 is - .
The letter I is used for the internal speaker. The positive pin number 16 & ground pin number 10, letter G
Good Luck!
Have more questions? Please feel free to ask.
Mike
Soundstream ribcom500
You can get the schematic from SoundStream. If you get the schematic and need help, email it to me at:
[email protected]
If the amplifier does nothing, post the DC voltage on each of the pins of the SG3525 (or whatever IC they're using in the supply). Use this as a template:
Pin 1:
Pin 2:
Pin 3:
Pin 4:
Pin 5:
Pin 6:
Pin 7:
Pin 8:
Pin 9:
Pin 10:
Pin 11:
Pin 12:
Pin 13:
Pin 14:
Pin 15:
Pin 16:
15helpful
2answers
I need reset pin number
To reset your pin on your base station, you push Menu, scroll to System Settings, DON'T PUSH SELECT, push * 6 5 # That will reset the pin.
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
