Would
you like to review the features of the HTC HD2 cell phone?
Have
you lost your HTC HD2 cell phone Owners Manual?
Would you like a
digital, searchable, pdf version of the HTC HD2 cell phone Users Guide? Follow this link (& click FREE) to download a
pdf version of the HTC HD2 cell phone documentation.
I hope that
helps. ___________________________________________
The HTC HD2 Smartphone may be affected due to virus or malware which is causing restarting and screen freezing problem. The virus or malware can infect the HTC HD2 Smartphone by the means of Bluetooth or PC Connectivity. To disinfect or remove the virus from the HTC HD2 Smartphone or from memory card it contains, scan your memory card using the anti virus installed in your machine.You can scan you memory card for antivirus using the Avira anti virus.Please download the anti virus from :
Install the software in your computer.Remove the memory card from the phone and connect in your machine using the memory card reader and scan the card for viruses or malwares.
You don't need to install any special PC suite software when connecting your HTC HD2 to your computer. Just connect it using a USB cable and you will be ask to choose the type of USB Connection that you want (Active Sync, Disk Drive or Internet Sharing).
To know more about HTC HD2, you can open this FAQ section of HTC's website.
It seems that you have to update the software of HTC HD2 Smartphone. HTC provides Rom Upgrade in which it completely replaces the built - in software in the phone. Rom upgrade in the HTC HD2 Smartphone extends its features, imroves its performance which makes it easy to use.
Download the Rom Upgrade from the link provided below :
Rom upgradation completely erase the personal data and the customized settingsor any installed programs in the HTC HD2 Smartphone. Before Rom upgradation pleas backup all your data.
Please visit the below links to backup your data before upgradation :
http://www.htc.com/www/howto.aspx?p_id=297&id=191
http://www.htc.com/www/howto.aspx?p_id=297&id=187
During ROM upgrade, make sure that your phone battery is at least 50% charged. Automatic standby and hibernation are disabled in computer, and close all running programs. Do not disconnect your HTC HD2 Smartphone from your computer while the phone software is being updated. If
you disconnect the HTC HD2 Smartphonee during the software update, it may become
unusable.
Hi. Unfortunately your digitizer/touch pad needs to be replaced. No matter what you try u will have to replace it. You can buy it here. http://cgi.ebay.com/HTC-HD2-GLASS-TOUCH-SCREEN-DIGITIZER-REPLACEMENT-OEM-/370508846486?pt=LH_DefaultDomain_0&hash=item56440c5596
The HD2 is an amazing phone but unfortunately this happens allot. If your phone is still under warranty you can contact your service provider, or you can chose to contact HTC and have them send you a replacement phone.
install it and connect the phone with usb cable and run this app.
but if you have HD2 then,
for htc HD2 windows mobile : download the WMDC (windows mobile device center) for win7/vista PC or PC SYNC 4.5 for XP and install it to use your Windows phone 6.5 device.
1. Flash HardSPL3 on HTC HD2 2. Flash any HTC HD2 Radio ROM Leo_RADIO 2.08 onward
Guide to install and run mattc Leo + Froyo w/Sense 1.7 build
1. Download zip file here. 2. Extract contents of zip file to your SD card. Note - Android folder should be located at root level (SD card\Android). 3. Using file explorer in Windows Mobile, inside the 'Android' folder run CLRCAD.exe (to fix audio issue). Don't worry, it will appear to do nothing, that is normal. 4. Run Haret.exe. 5. Enjoy...
Note - Android 2.2 Froyo on HTC HD2 is not perfect yet compare the actual Android phone HTC Desire. Some functions are not working. And I got white and black screen of death (SOD) sometimes. But it is getting better and better each day. Hoping it will out perform actual Android phone out there soon.
try active sync->file->connection settings->this computer connected to (select the internet) also try checking the box for 'allow connection to one of the following' option.
