Maybe there are buttons on the remote or tv set that are stuck, check these. If no luck then hide the remote so it can't communicate with the set, if it still is acting up unplugg the set for 30 min or more and plug it back in. This may clear a fault that is stuck. If it still is not working correct then the tuner is going bad. Check all devices that are plugged in to the set and unplug them from the tv so the tv does not recognize there is a device connected this may also help.
Testimonial: "Thanks dcramer531, spot on diagnosis. I removed Scart lead from DTV2; problem solved."
Check the TV/AV button on your TV and on your remote, it might be stuck. Try removing the batteries on your remote too and see if it will stop it.
1 Press PIC. FLIP to display the
PICTURE FLIP screen.
2 Press PIC. FLIP to change the
setting.
It rotates through several options -- normal, mirror (where you are), rotate, upside down. When you get the picture looking right, stop and the screen will disappear in 3 seconds. See Page 28 of your manual for another option, using the Menu screen.
It I
