I brought an Uniden set to India from US.I unknowingly used that without a transformer.Now the charger is not working?Is the charger repairable or I should buy new?
It is hard to say. If the device has a fuse fitted inside then it may only be that needing replacement. If the motor or other circuitry is burned up, then just buy a replacement unit.
You can use the original charger on your headphones without the need of a step down transformer. It is possible that the age of the battery is causing your problem too.
Hi, do not experiment with other chargers (its not worth, because of price for new one), the cheapest one (with most positive reviews from buyers) is Amazon com PHILIPS NORELCO G370 charger . hope this was helpful.
go to a company store that your phone works with and tell them you would like an unlock code so you can use the phone abroad they should help you without a problem
In Iraq I assume the voltage is 220-250. The fuse you'll need is a 220-240V 1.25A H 250 V. You can actually use this model without a transformer/converter if you have the voltage selector set to the non-North America setting.
Play well!
I successfully reset Radio Shack (Uniden) 5561 handset by reconnecting the battery while holding the '*' and '#' key, then press the right upper soft key near the LCD window. The display will indicate "EEPROM/RAM cleared!!" and will return the handset to the factory default condition - looking for a base to register to.
