HI...............
The HP printers come with the HP
Solution Center software. The software allows you to adjust settings,
transfer images, send a fax and make copies right from the control
center instead of using the printer control panel. When you make a fax,
receive a fax or block faxes, a log is kept in the HP Solution Center.
You can use the software to view faxes and delete a fax log history.
How to Delete a Fax Log History on an HP????
Difficulty:Moderately Easy
Instructions
HOPE THIS SOLUTION WILL HELPFUL TO YOUGOOD LUCK.................
You can try this,
"A 'Fax Log Full ' message displays on the control panel display when the Fax Log is full."
1. Press the Setup button ("Spanner logo")
2. Press the Right arrow button (?) until Tools displays on the control panel, and then press OK .
3. Press the Right arrow button (?) until Fax Log displays on the control panel, and then press OK .
4. Press the Right arrow button (?) until Clear Fax Log displays on the control panel, and then press OK . A message that says the fax memory is clear displays on the control panel.
5. Press the Cancel button (X) to exit.
Hope it helps.
